February 1Feb 1 I have some simple If-Then-Else programs that set a scene on or off, but Eisy-ui lists those scenes as 'undefined'. See below,In the Admin Console:NightLights - [ID 0003][Parent 005B][Run At Startup]If$s_Night_Time is 1ThenSet 'NightLights Scene' OnElseSet 'NightLights Scene' OffEisy-ui shows this:If$s_Night_Time is 1ThenSet 'undefined' OnElseSet 'undefined' OffDoesn't seem to be causing any execution errors; that scene is being switched on/off properly.
February 1Feb 1 Did you make a recent move to eisy? What color is the programs icon if you look at the program's status... is it yellow.If it's yellow, it might be due to migration, and you need to go into the program, re-pick the right item to replace undefined and resave it
February 1Feb 1 Solution @Phil G Eisy-UI doesn't yet support scenes, thus the "undefined"eisy-ui is a work in progress so hopefully the next release will have scene support
February 3Feb 3 The next eisy-ui release will show scenes & folders in the Nodes page.Programs with a scene will show the scene name as one would expect.The ability to edit or view the content of a scene will be implemented later though.
