iAquaLink Solar Heater ENABLED Option in Then/Else
In the IF section of a program, I can check whether my Solar Heater (solar panels) are N/A, OFF, ON or ENABLED.
However, in the Then/Else Section, I can only Set it to ON or OFF.
I would like to be able to Set it to ENABLED as well, but it's not an option.
Just FYI - the ENABLED option allows the system to compare the solar panel temperature to the pool temperature and automatically switch the valves accordingly.
My current workaround is to compare outside air temperature to the pool. This is pretty close; however, the roof is hotter on a sunny day than the air temperature.
Thank you,
Ross
