16 hours ago16 hr Program 'Alarm!!+’ not working:'Alarm!!+' Program – Enabled is checked and program savedWhat is supposed to happen: If Insteon sensor switched ON, Set scene 'ALARM_All_Lights' = ONPolisy Log – Sensor is switched ON - see attachedScene ‘ALARM_All_Lights’ does not turn on when sensor is switched onIf I manually execute the 'Alarm!!+' ‘Run Then’ the Scene turns on and notifications are sentGhosts in the machine... What could be wrong?ThanksStew Progam not working on sensor control - switched to ON 20260218.docx
14 hours ago14 hr Author An Insteon IOLinc v.41 is connected to my alarm relay outputs. When the Alarm is tripped, the relay output closes. The IOlink registers the closure of the circuit and Polisy recognizes the switching to 'closed'. I have verified that the AC console reports the IOLinc circuit closure when the alarm is tripped and reports the circuit opening when the alarm is cleared.
14 hours ago14 hr Author '12129Td/Alarm/ALARM - Intrucsion-Sensor' is switched On.BTW - This worked about a year ago. Recently the house alarm tripped and I realized the ALL Lights scene was not turning on.
13 hours ago13 hr The IOLinc is a powerline only device, if you have noise on the powerline at the time the alarm triggers the IOLinc may not send its status..Can you put the controller log into level 3 mode and then set off your alarm and post a copy of the log. Edited 13 hours ago13 hr by Techman
13 hours ago13 hr 26 minutes ago, SSamuels said:'12129Td/Alarm/ALARM - Intrucsion-Sensor' is switched On.BTW - This worked about a year ago. Recently the house alarm tripped and I realized the ALL Lights scene was not turning on.So it's looking for the control event, therefore it's not a status change issue. If you're seeing the status update in admin console then it's certainly getting the control event.
13 hours ago13 hr Author Level 3 log ISY-Events-Log.v6.0.4__Wed 2026.02.18 04.17.06 PM.txtThe IOLinc's address is 42.4.E3
11 hours ago11 hr Your controller is seeing the status of the IOLincWhen you trigger the alarm does your program, '12129Td/Alarm/ALARM - Intrucsion-Sensor' show as red or as green in your program tree? You might also try deleting and recreating the program.
11 hours ago11 hr Author When the alarm is trigged the program is Green.I will try deleting and recreating.Thanks
2 hours ago2 hr 9 hours ago, SSamuels said:When the alarm is trigged the program is Green.Unless your program runs false, it will always show as green. I am not sure that we can conclude anything from this. Instead, I would look at the program summary tab and see when was the last time the program ran. If the time does not match that of the most recent alarm trigger, then it did not see the signal.Given the evidence (log and IOLinc status) suggests that the Polisy IS receiving the IOLinc status, have you checked to see if the program somehow became disabled? Is the program in a folder that somehow because disabled? Edited 2 hours ago2 hr by oberkc
