ZWave LR support
Apologies if this is covered, my search was inconclusive.
My controller appears LR-aware internally and I am able to add using DSK value, but I don’t see any user-facing way to enable or verify LR. Is LR currently supported on eisy, and if not, is it planned? I have a single device that would benefit.
TY
To use Zwave LR the device must be included with S2 AUTHENTICATED security enabled.
Unfortunately I haven't found a way to determine if a device was installed as Mesh or LR as the include process doesn't appear to offer that option
Found this on the web:
SmartStart Requirement: Z-Wave LR requires inclusion via SmartStart (scanning a QR code). If you added the device using the "classic" manual pairing method (pressing a button on the device), it was almost certainly added as a standard Mesh node.
Well I added a Weiser lock using it's PIN code (printed next to the QR code). The node title shows "Door Lock [S2 Access] [S0]"
Just now, Guy Lavoie said:
When adding it by pressing the pairing button, a pop up appeared in admin console saying the lock was requesting S2 security, with a checkbox for both S0 and S2 (both checked). It would only let me proceed with the S2 box checked if I entered the PIN code.
Edited by Guy Lavoie
I have started using smart start via the UD iPhone app which lets you scan the QR code, and I choose s2 when I am offered the choice. I have not been able to determine if it joins the device as a p2p link or mesh.
I have read Michel comments that there is no official support, I am just trying to understand if there is comm/protocol support for LR since I have a use case that may require it.
thanks for feedback and info.
Edited by walkman9999
Typo
The UDI Zwave/Matter/Zigbee board is Zwave LR certified however the current eisy/polisy firmware appears not to support Zwave LR, only Zwave mesh
The following is from the web:
To include a Z-Wave Long Range (LR) device without using mesh, ensure your controller (700/800 series) has firmware that supports LR, set the controller region to "US-LR", and use SmartStart (scanning the QR code) to provision the device, specifically selecting the "Long Range" protocol instead of mesh. LR devices communicate directly with the hub, bypassing mesh routing.
  • 3 weeks later...
Hi,
Do you by any chance have any experience with Kwikset 620 series (Z-Wave Long Range version)?
https://www.amazon.com/Kwikset-HomeConnect-Convenient-Customizable-Contemporary/dp/B0DWGF32GD?th=1
I have currently 4 Kwikset locks (910 series - regular Z-Wave) and ancient ISY-994ZW (4.9.0)
Despite of my all troubleshooting efforts, which included but was limited to adding extra Aeotec Range Extenders,
the connectivity between ISY and Locks was always flaky. Few years back, I decided to give it up, and all my locks
were standalone (offline). Now, after 8 years, the locks are worn out because of exposure to elements, and needs to be replaced anyway.
This time I am ready to replace ISY with eisy r2 hardware, and want to make everything working again from a new start.
That is why I am on the market for new locks. But after reading this thread I am confused.
Are Kwikset 620 Long Range version going to work with ZMatter USB dongle and eisy r2?
If it is not supported or possible to provision them in LR mode, would it be possible to fall back to regular Z-Wave mesh?
Is it worth to buy LR version and wait for future upgrade to eisy r2 firmware to provide LR support (LR version is actually cheaper)
Or I am going in a completely wrong direction and I should look at something else altogether?
One think about my installation worth noting is that I have about 100 Insteon devices, and I need to support them.
Any recommendations or thoughts?
Przemek
Even though the Zwave/Matter board is Zwave LR certified it appears that the current software doesn't support LR. I have an open ticket and should know more next week and will post the results
  • 2 months later...
Hi all, I am a little late to this "party", but having read this string of messages I am just as confused now as before.
1- Does the UDI dongle and EISY, as a system, support LR?
2- If it does, exactly how is it implemented?
3- I have several name brand 800 series ZWave devices that pair with EISY but do not function properly. Has anyone seen this,
4- I am getting ready to purchase some Aquara Matter sensors. Does anyone have any first hand recommendations? Will it work with the UDI dongle/EISY?
My apologies if this is redundant but I need to find some solid answers before I spend more cash and mental anguish. Any pointers are appreciated. Thanks..
@KSchex
The UDI dongle supports Zwave LR, however, currently the UDI software/firmware portion of the equation is still being developed. Hopefully it shouldn't be too long.
What 800 series devices are you having a problem with. I use mostly Zooz 800 and they all work without issues.
The last I heard UDI matter was still in beta testing.
3 hours ago, Techman said:
@KSchex
So what I understand is that LR is not usable nor is the Matter protocol., at this time. Thanks very much. I have been reading and digging for answers, finally, thanks. Actually I am a bit concerned; since ISY we have been through Polisy now two iterations of EISY. The "system" is still not up with the state of the art. It has got to be costing UDI a lot of bucks.
With regard to 800, I purchased 20 zooz 800 window & door sensors only to find out they did not function properly with the UDI dongle and EISY R2. They did not load properly showing all the nodes and locked up the EISY. I paid UDI for technical assistance which was a waste of money. I switched to Aeotec window/door 7 pro. Unfortunately the Aeotec has an expensive 3v battery and the Zooz has two AAAs.
Thanks again for your assistance.
@KSchex '
Being that the window and door sensors are battery operated you'll need several plug-in repeaters unless you have other zwave a/c powered devices in your zwave mesh network.
The Zooz devices should be compatible wirh the EISY. I have a variety of Zooz devices on my Eiisy R2 and have never had a compatibility issue
