Thursday at 05:50 PM3 days It is now possible to use eisy-ui remotely, from Portal.If you have not already done so, please upgrade to eisy-ui 1.0.1.Then on my.isy.io, a new eisy-ui option will appear under "Select Tool".For now, we left the older "ISY Web Access" active, but we may remove this option eventually.Enjoy!
Thursday at 07:19 PM3 days Under select tool, when I select eisy-ui I get the following: File not found: eisy-ui-1.0.1-2/index.html Edited Friday at 01:22 AM3 days by Techman
Friday at 01:06 PM2 days Author 17 hours ago, Techman said:Under select tool, when I select eisy-ui I get the following: File not found: eisy-ui-1.0.1-2/index.htmlPlease upgrade packages one more time.You need to be on 1.0.1.1.0.1_2 was temporarily available yesterday, but that version won't work with remote eisy-ui, and does not include any significant changes over 1.0.1.
Friday at 02:06 PM2 days @bmercierI did an upgrade packages (twice) and I'm still on 1.0.1_2UPDATE:I've tried several more updates and reboots, I'm still stuck on 1.0.1_2 Edited Friday at 07:07 PM2 days by Techman
Friday at 03:38 PM2 days My eisy upgrade via the AC from isy-6.0.5_1 proceeded without any problems.sysconfig.txt now shows: eisyui-1.0.1 pg3x-3.4.17And my.isy.io shows and opens the new eisy-ui option.Nice work UDI.
Friday at 05:54 PM2 days On 3/26/2026 at 1:50 PM, bmercier said:If you have not already done so, please upgrade to eisy-ui 1.0.1.Thanks @bmercier for the release. This worked great while away from home! Seemed to work really quick on my testing. Now, just need to get web access to be as good as the Java interface! 😉What I still don't understand is why doesn't the system page so true "upgrade to" versions? It didn't say there was an update needed to get this function. I saw you posted this and slid the comment to upgrade to 1.0.1. Making progress...nice! Baby steps.
Friday at 08:12 PM2 days Author 6 hours ago, Techman said:@bmercierI did an upgrade packages (twice) and I'm still on 1.0.1_2UPDATE:I've tried several more updates and reboots, I'm still stuck on 1.0.1_2Humm, maybe it won't "downgrade". Hold on, we will have 1.0.2 soon.
Friday at 11:35 PM2 days Author 3 hours ago, bmercier said:Humm, maybe it won't "downgrade".Hold on, we will have 1.0.2 soon.eisy-ui 1.0.2 is released. It may take a few hours before the upgrade page shows there is a new version. But upgrading it now should pick it up.
