4 hours ago4 hr Trying to setup dynamic DNS forwarding through my router with HTTPS. Router says port is open, nmap says port is open, but the browser reports "Site can't be reached" and <UNC> "unexpectedly closed the connection." and finally ERR_CONNECTION_CLOSED. Error message in ISY reports "System -170001 [TCP-Conn] -6/-140002, Portal-Dispatch".This error does not appear in the ISY error list at "ISY-99i/ISY-26 INSTEON:Errors And Error Messages".Any clues? I have tried adding the WEB/xxxx paths after the UNC without effect.Thanks!
1 hour ago1 hr Who is your ISP? A new technology on the ISP scene is CGNAT, where they put a NAT router between your router and the internet, which renders local firewall holes ineffective. They're doing for a different reason, but the effect is the same.CGNAT is the beginning of the end of opening firewall ports to access your local devices.
