solaredge plugin now getting API request failure
Several weeks ago my plugin started getting an "API request failed" error. I see this same error with the production plugin and the non-production plugin. I've confirmed that its not just me as GQuack is seeing the same error. I've reached out to solaredge to see if they have changed the API but couldn't get anyone knowledgeable. My installer hasn't been able to get any response either. Are others seeing this issue? Any ideas what might be happening?
2026-04-16 19:46:57.748 Command    udi_interface.interface DEBUG    interface:_handleInput: PROCESS custom message {'customparamsdoc': '<h2>Configuration</h2>\n\n<p>The SolarEdge node server requires a valid API key to access your site\ninfomation.  You can obtain an API key by logging into your SolarEdge\nmonitoring account.  From your monitoring dashboard select "Admin" and go to \nthe "Site Access" section.  Near the bottom of the page is a section to\nenable API access and get an API key.</p>\n\n<p>Copy the API key to the api_key custom parameter below.</p>\n'} from Polyglot
2026-04-16 19:46:57.748 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message customparamsdoc from Polyglot
2026-04-16 19:46:57.751 Thread-2 (handleParameters) udi_interface ERROR solaredge-poly:_api_request: Request failed: Expecting value: line 1 column 1 (char 0)
2026-04-16 19:46:57.751 Thread-2 (handleParameters) udi_interface INFO solaredge-poly:handleParameters: API request failed. Invalid api key?
2026-04-16 19:46:57.792 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc
2026-04-16 19:46:58.342 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
