April 17Apr 17 Hi I have an ADT security system with wireless sensors on all doors and windows. My rental clients are leaving the doors and windows open while the AC is running. How can I access the ADT door/window status and can I control the Venstar thermostat from EISY?Thanks allJoe
April 17Apr 17 Some missing info: Do you have ADT and Venstar plugins for Eisy, working?Which Venstar- Old school Insteon, Color Touch, or?I can speak to the Color Touch. Create and iox programs. This is more pseudo code but you can find the right things in the eISY interface:If Window 1 is openor Window 2 is openor. Window 3 is open (keep following the pattern, use 'or' for catching any one of them)Then Set Venstar Mode = OffThe slipperier slope is do you reverse it if they close all the windows? If yes, then its a similar program, but with "and"s instead of "or"s. With "and"s, they all have to be closed. But when they close the windows it might because it's cold out and you're turning on the air. I'd start with the first program above and see how it goes. They'll figure out the system is off.
April 17Apr 17 Author Hello World...I do NOT have the ADT nor Venstar plugins installed. I could not find where to add them nor how to in the admin console...Help here would be appreciated.I have the Venstar Colortouch thermostat (wifi) and the ADT "pulse" I believe.My initial strategy was to have the AC turn off if a door or window was left open for ~20 minutes. Then enable the thermostat when all doors and windows are closed. The AC has it's own short cycle protection.We have had two sets of guests leave doors open for up to 11 hours when the AC is running...we would provide a placard to the guests that the AC is smart and will shutoff if the doors or windows are left open.RE: AC or Heat...we set the heat or AC setting before the guests arrive.Thank you all for your help!
April 18Apr 18 You're still new to the eisy, or have never worked with plugins? Click on "plugins" at the top in admin console and then "Launch Polyglot", and log in with your admin login and password. You'll probably get a safety warning, which you can override. Once in, click on the "Plugins store" and find the VenstarCT plugin, and install it. Try it first in demo mode. There are instructions in "more info".I'm not familiar with a ADT plugin and don't see one listed. Anyone else familiar with this might be able to say something about that.
April 18Apr 18 Author I accessed Polyglot OK. I have had theUD devices for a long long time but have not ever used Polyglot...I did not know what it was.I could not find an ADT plugin nor anything that sounded like it could get the state from an ADT wireless sensor (or the ADT app if that is what the plugin API means...) Does someone know the name of the appropriate ADT plugin?I did find a single Venstar plugin. VenstarCT by W. Randy King (Goose66)I have guests till May, so I won't monkey with the EISY till we are empty.If I cannot access the ADT sensor states, I will have to add Zwave door and window sensors. Any recommendations on those for EISY? I would prefer AAA batteries. I have a pretty good number of ZWave nodes. Thanks group.Joe
