IoX finder
iOS finder always starts full screen, even when I resize it. Any solutions?
@oamber you'll need to find the .sate files for UD. Depending on your computer OS. Referenced in the wiki. Look for these and delete them all (make sure admin console and finder are closed before you delete these files).
https://wiki.universal-devices.com/Main_Page#Admin_Console_Minimized/Invisible_and_Cannot_be_Restored
(In macOS it looks like they might be in /var/folders (try typing open $TMPDIR in Terminal) - I don't know macOS, but Google told me that)
Then if you're on Windows to right click on IoX Launcher shortcut and make sure the "Run:" option is "Normal Window"
I'm a Windows user, in windows you can hold down the control key when closing the window to set the size, not sure about the MAC
As @Geddy suggested you should try to locate the .STATE files and delete them. The will rebuild the next time you open the launcher
