ISY Lockup Issues
A couple weeks ago I found that my ISY was locked up. It had not been rebooted in a long time so I restarted it and it worked fine. In last few days, the same problem has occured 5 times. The ISY will not respond to admin console requests, web server requests, or to the HomeSeer plugin. It just locked up and before I could plug in a serial cable to view via RS232 interface we had a power outage .. it restarted and looks okay.
What should I look at now or after it locks up again? The error message in the HomeSeer log follows:
8/14/2010 5:40:18 PM ISY Insteon COMM: ISY network communication failed to read message data: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Following is from HyperTerminal when restarting ISY
Starting the Device
Starting Device Communications Services
Initializing the Driver
PLM: E.D9.1 v72
Starting the SSDP Agent
Starting the Secure Web Server
Starting Telnet Service
Starting Module Services
H_ERROR:-110022 : /CONF/ELEC.CFG
LOGGER:-110022 : n=[null] c=[/CONF/E] a=[null]
H_ERROR:-110022 : /CONF/ADR.CFG
LOGGER:-110022 : n=[null] c=[/CONF/A] a=[null]
H_ERROR:-110022 : /CONF/FYP.CFG
LOGGER:-110022 : n=[null] c=[/CONF/F] a=[null]
H_ERROR:-110022 : /CONF/WEB.CFG
Starting the Schedule/Trigger Service
LOGGER:-110022 : n=[null] c=[/CONF/W] a=[null]
Starting IR
Query All Devices
Installed Modules:
1. (21010) Open Auto-DR
2. (21040) Networking Module
Waiting 2sec to start 'A' to abort
Configured IP = 0.0.0.0
Configured Mask = 0.0.0.0
MAC Address= 00:21:b9:01:01:64
--- Product : (1050) ISY 99i 1024 IR ---
Max Nodes & Scenes: 1024
Starting ISY
Configuring the File System
Loading System Configuration
Refreshing Device Configurations
Loading Nodes Configuration
Starting the Logger Service
Starting the Time Services
Initializing SSL Services
SSL Key Size: 512
SERIAL:Connect: port=0 baud=19200 stop=1 data=8 parity=0 : synch=true pd=3
Starting the Alarms & Notifications Service
Retrieving Nodes
Starting the Logical Device Updater Service
Binding the UPnP Device
Starting the Security System
Starting the Sheü
Please Log in
Username:
Starting the Device
PLM: E.D9.1 v72
Starting IR
Query All Devices
Installed Modules:
H_ERROR:-10103 :
H_ERROR:-10011 :
LOGGER:-10103 : n=[null] c=[null] a=[null]
LOGGER:-10011 : n=[null] c=[null] a=[null]
Starting ISY
SSL Key Size: 512
Retrieving Nodes
Starting the Sheü
Please Log in
Username:
Starting the Device
H_ERROR:-110022 : /CONF/134A6F.REC
H_ERROR:-110012 : /CONF/134A6F.REC
LOGGER:-110022 : n=[null] c=[/CONF/1] a=[null]
LOGGER:-110012 : n=[null] c=[/CONF/1] a=[null]
PLM: E.D9.1 v72
Starting IR
Query All Devices
Installed Modules:
LOGGER: -2 : n=[13 48 FB 1] c=[ ] a=[ ]
LINK: Cannot write high water byte: FF8 : 0 : to device A 34 B9 1
Installed Modules:
Installed Modules:
H_ERROR:-140005 : Net Module Rule: 14
LOGGER:-140005 : n=[null] c=[Net Mod] a=[null]
Installed Modules:
H_ERROR:-110022 : /CONF/A34B9.REC
H_ERROR:-110012 : /CONF/A34B9.REC
Log file open failed /LOG/A.LOG
H_ERROR:-100002 :
LOGGER:-100002 : n=[null] c=[null] a=[null]
H_ERROR: -2 : [uNKNOWN ] 02 E1
LOGGER: -2 : n=[null] c=[[uNKNOW] a=[null]
Installed Modules:
Password:
Authentication failed
Please Log in
Username:
Password:
Please Log in
Username:
Password:Waiting 2sec to start 'A' to abort
Starting ISY
SSL Key Size: 512
Retrieving Nodes
Starting the Sheü
Please Log in
Username:
Starting the Device
PLM: E.D9.1 v72
Starting IR
Query All Devices
H_ERROR:-5012 :
LOGGER:-5012 : n=[null] c=[null] a=[null]
H_ERROR:-5012 :
UDQPOST: Queue Full: LD
H_ERROR:-5012 :
H_ERROR:-5011 : uuid:00:21:b9:01:01:64,0
. Many of same repeats removed
H_ERROR:-5011
LOGGER:-5011 : n=[null] c=[uuid] a=[null]
Michel:
I am rebooting it by removing power when I find it locked. Not certain if it has rebooted itself at other times that I did not notice.
Paul
Hello hart2hart,
Please upgrade to 2.8.1.
Also, please do let me know the PLM firmware version number. We have had reported lockup issues with PLM version 72 and upon reboot. If you also have device communication errors, I do suspect the PLM to be the issue.
But, again, before anything else, please try upgrading to 2.81..
Michel:
The PLM is v72. Do the 5011 and 110022 codes listed in above post suggest more about this issue or is this just normal startup behavior?
Paul
