May 20May 20 Any ideas how to resolve this? It seems the Isy is stuck trying to query the Elk module. I've never used Elk, nor have I enabled an Elk module.
May 20May 20 @JCox have you attempted to power cycle the ISY994? Since you don't use Elk it probably wouldn't harm things. Did you attempt to generate a Topology and this triggered something with Elk? What Firmware are you running on the ISY994 (it should show on the launcher window before you log in if you're not able to access the system and operate it).
May 21May 21 Author @Geddy I've tried all sorts of things (power cycle, factory reset with backup restore, etc.). The ELK-ERR "system busy" keeps popping up. I do not believe I've attempted a Topology (not sure how I would do that). I'm operating on Firmware v.5.3.4
