Monday at 08:47 PM4 days Hi All. ANYONE out there with a Zooz ZSE70 able to view and use the Temperature data it is supposed to send? None of my nodes for it show Temperature but it is one of the main advertised features of this sensor and one that I want to use. ANY feedback appreciated. I am currently on v5.8.4 on a Polisy but have an eISY for spare that I will eventually move to - I will move to it sooner if someone tells me that it will enable seeing & using Temperature from this sensor. Thanks!Shawn
Monday at 11:32 PM4 days I have an EISY with 6.0.5 firmware and the ZSE70 shows the temperature. You should probably try updating your Polisy/Eisy firmware
Tuesday at 03:21 AM3 days Author 3 hours ago, Techman said:I have an EISY with 6.0.5 firmware and the ZSE70 shows the temperature.You should probably try updating your Polisy/EisyDo you remember when you installed your ZSE70? Or, do you remember what level you were at when you installed it?Thank you, but correct me if I'm wrong - the next version after mine (5.8.4) had a good chance of bricking your Polisy, right? (no prob for eSIY) Also, I thought not long after that they stopped Polisy from getting new versions before the v6.0.0 arrived?Thanks!
Tuesday at 01:52 PM3 days It's best to open a support ticket before you try to upgrade your Polisy . See the link belowUpdated Software Available! - Current Release Announcements - Universal Devices ForumYou'll want to have the lastest firmware versions on your Polisy and EISY before you migrate from the Polisy to the EISYDo you have the UDI Zwave/Matter board on both the Polisy and Te EISY?
