June 13Jun 13 My ISY994i pro is starting to glitch and I'd very much like to not be dependent on UDI for yet another piece of hardware that I'll just have to replace in a few years.I see my two main choices are 1) Use a PLM directly or 2) Get a Hub 2 and then integrate HA with the Hub.I'd rather integrate directly with the PLM but it seems native Insteon scene management may be an issue unless this has been implemented in HA since. Otherwise if I want native scene management, I'd have to go Hub 2 which kind of sucks since that's the only thing I'd be using the Hub for.Has anyone done an ISY to HA migration with stories to share?I'm considering eisy but would rather take a route that depends on as little bespoke hardware as possible. I pretty much have to use a PLM with my Insteon ecosystem but I'm hoping that's the line I can draw at specialized hardware.
June 13Jun 13 13 hours ago, sorka said:My ISY994i pro is starting to glitch and I'd very much like to not be dependent on UDI for yet another piece of hardware that I'll just have to replace in a few years.I started with UD back in the early 2000's with a an ISY-26. I think I paid <$200 for it. It served me very well for better than a dozen years. I then moved into the 994, it too served well only and until the mail notification stopped (not due to anything UD did wrong). The 994 cos around $200. When it became apparent that the 994 was going to be sidelined - I procrastinated for months. I finally, even though advised by UD to just hang on to it and give up on the email notifications, and knowing of possible issues I might have integrating my Schlage locks into a new eisy, I bought a new eisy for ~ $400 something. I even sold the old 994 for $100 to a guy who needed it for what it was! The transition from 994 to eisy could not have gone better. No issues - and I mean NO ISSUES. The locks were seamless and other than a few switch(s) that have had to be factory reset and restored my system has been 100%. Granted, I don't have a huge setup, < 50 total switches. My point being that I feel that UD (and more importantly Michel) are worth every penny I ever paid them. Their product works as advertised and support is second to no one. I will never utilize the eisy for 5% of its capability, but that's OK. I like stuff that works and my ISY(s) have always done that.
June 14Jun 14 What are doing with your system? Insteon only?HA is a totally different beast and has a learning curve
July 25Jul 25 I'm curious what your ISY gitches are. Only saying that as I once decided to just fully reset and reload, resetting the PLM as well. Seemed to resolve my random quirks. Later for other reasons I updated to a Polisy, but not after considering using HA direct with a PLM. While it's possible, the level of integration was a no go for me. HA does have scenes, but that's not the same as an Insteon scene. ISY makes management of Insteon so easy. Should I say "eisy" instead?! 😉 I manage all my scenes and low level automation, like keeping devices synced as well as simple scheduled events. I use HA for higher level automation and integration. That multi layer approach works great for me. I don't have any cloud dependencies.You can always backup your system and try it building an Insteon scene in HA. When you decide that's not the route for you, you just restore the PLM from the ISY.I have no Hub experience so can't speak to that as an option.
