August 2Aug 2 I Have an Eisy with the Zigbee dongle. I had modified a Zigbee door contact to notify me when my generator is running. The door contact failed after working for a year, and I attempted to replace it with a similar one. When I tried to pair the new contact, my Eisy seemed to lose its mind. It kept interviewing non-existent Zigbee devices and I couldn't make it stop. After 20 minutes or so I rebooted the Eisy. It shows a couple new Zigbee devices (that don't actually exist), but my new device is not in the list. What happened? How can I fix this?Thanks for any advice.-Rick
August 2Aug 2 Author 5 minutes ago, Guy Lavoie said:Try doing an exclude on the new device, then adding it.Thanks, but since the new device does not show up, how can I do that?
August 2Aug 2 1 hour ago, rick.curl said:Thanks, but since the new device does not show up, how can I do that?A Zwave exclude doesn't need to have the device existing on your controller. You go into the zwave menu -> exclude device and then press the button or whatever on your device (usually the same as adding a device). That clears any links it has to a controller. Then try the add process again.
August 2Aug 2 Author ....But this is Zigbee, not Zwave. I don't have the menu option to exclude a device.
August 2Aug 2 Ah yes, my mistake! I see ten zwave questions for one zigbee. Sorry, dementia must be setting in... Zigbee devices will usually have a factory reset procedure. Did you also try bringing it close to the dongle for adding it?
Yesterday at 01:55 PM1 day Author Update: The sensor I am trying to add is a Sercomm SZ-DWS08(N), and apparently it makes my Eisy go nuts every time I try to pair it. Time to abandon this sensor and try something else. BTW- I did try factory resetting the sensor, but it didn't help. I am looking for a Zigbee door/window contact that has a reed switch (instead of a hall effect sensor) inside. The reason I need one with a reed switch is that I will be hacking it to attach wires so I can connect it to a relay contact on my Generac generator so I will get notification when the generator is running. Can anyone recommend a Zigbee contact that will work?Thanks.-Rick
