Friday at 02:19 PM2 days I have a Zooz ZSE11 800LR that uses battery-only power, and was included with battery-only power applied. I have parameter 172 Reporting Frequency set to 4 hours, and parameters 183-185 (temp, humidity, and lux reporting thresholds set to to 0). Per the zooz documentation (https://www.support.getzooz.com/kb/article/1003-zse11-q-sensor-advanced-settings/?section_id=251), this should result in battery level being reported every 4 hours, but the Battery Level field remains blank forever. Anyone else have this issue?
Friday at 02:37 PM2 days Author Update: In the AC, all the ZSE11 devices had the 1011 icon shown. I did a right click/Write Changes followed by a press of the zse11 zwave button. The Battery Level field then showed 100%. The 1011 icon remains after the Write Changes has (apparently) completed. I'll have to wait and see if the Battery Level field updates going forward.The 1011 icon is supposed to indicate that there are pending changes for the device. The fact that the icon persists may indicate an issue?
Friday at 07:39 PM2 days The ZSE11 batteries may need replacing or you may have a marginal connection between the device and your controllerHave you updated the device to the lastest firmware, 2.3.0, which was released 7/2026
Friday at 08:56 PM2 days I don't have the ZSE11, but I do have a number of Zooz ZSE42 Leak Detectors which are also battery operated. My experience with those devices is that there is sporadic reporting of battery status, including sometimes never reporting battery level.I know the battery is OK only because I have a message sent every time the device "wakes up". And when the devices wakes up, I also programmatically have the device queried in the hope of getting the battery data. Rarely happens.The devices work, but Zooz support, while very responsive has typically told me, the ISY/eISY are not an "officially supported" system, so it is "most likely a problem with the eisy". In other words, while responsive, they have rarely been helpful with battery operated devices in particular.It would be helpful if UD would work with Zooz or vice versa to improve many aspects of ZWave support of Zooz products.Rob
Saturday at 12:19 PM1 day Author 16 hours ago, Techman said:Have you updated the device to the lastest firmware, 2.3.0, which was released 7/2026I updated from firmware 2.0 to firmware 2.30 . It was necessary to do an exclude, then an include with a power supply connected in order for the firmware update to work. After then excluding, then including with batteries only, the 1011 icons are now gone. The Battery Level is being reported as 100%. The batteries are fairly new, so it remains to be seen how the reporting works as the batteries age.
8 hours ago8 hr Author On 8/15/2026 at 8:19 AM, wmcneil said:I updated from firmware 2.0 to firmware 2.30 . It was necessary to do an exclude, then an include with a power supply connected in order for the firmware update to work. After then excluding, then including with batteries only, the 1011 icons are now gone. The Battery Level is being reported as 100%. The batteries are fairly new, so it remains to be seen how the reporting works as the batteries age.After some 36 hours have passed, the Battery Level field is now blank. Per the documentation, it should be updating at least every 4 hours: I have the threshold parameters (183,184,185) set to zero, and the reporting frequency (172) set to 4 hours. The documentation states that parameter 172 is not applicable to the 800 series version of the zse11, but it is present and set to 4 in my zse11 800LR .
7 hours ago7 hr It's posible that when you switched to batteries it cleared the status in the battery window.Give it a couple of days to see it it populates the battery level.
