August 27Aug 27 Had power issues from a storm and ISY was throwing errors, but still worked and I could get to it from the portal. Now I and trying to put a new SD card in it and load up 5.3.0, then do a restore, but no luck finding it via the finder. I totally removed java, rebooted, re-installed java, cleared the cache, rebooted and the ISY is still not found. Any ideas?
August 27Aug 27 Power surges often take out the power supply or make them flaky. I would try that first.Next, try pinging the ip address of your ISY. See if is even booted up. Or just try to ssh into it.Depending on your model, check out the led lights on it.Wouldn't be surprised if you need to open a ticket. Though if it is not an eisy, they no longer support the older stuff.
August 27Aug 27 Author I have no problem pinging my isy and there are no error lights, it just does not see it in IOX finder and cannot connect locally to the console. even the UD Mobile app works and controls things, just a couple things are flaky. I tried to ssh to it but that did not work.
August 27Aug 27 If you can ping the ISY you should be able to manually add the address:Click the "Add" button and manually add the local address as shown. Also add an address for http ( http://xxx.xx.x.x/desc).After doing this click "save" and save the configuration to a local file for the Next time things are lost. Use the "Load" command from the file you created. My "saved" file is from 2022, still working.
August 28Aug 28 Author I have tried that multiple times and it did not work, but is now working by adding the IP. The problem is I cannot connect to the isy to install a new SD card. I can ping it, just cannot connect to it after i put in the new card.
August 28Aug 28 22 minutes ago, bdw72 said:I have tried that multiple times and it did not work, but is now working by adding the IP. The problem is I cannot connect to the isy to install a new SD card. I can ping it, just cannot connect to it after i put in the new card.Curious that Mobilinc works but you can't connect locally. When you do a manual "Add" in the IOX finder, what does it show you when you try to connect?You could also try to connect to the ISY shell via Telnet - https://docs.universal-devices.com/production/ISY%20Advanced%20Configuration%20Guide.pdf Edited August 28Aug 28 by IndyMike
August 28Aug 28 Author Oddly, I can telnet to it, it connects but will not let me login when i put the new card in it. With the old card it works fine. IOX finder show all the expected information.
August 28Aug 28 New card not formatted properly or incompatible? Is it truly a new unformatted card?If it's the correct card size you could copy the files from the old card using a PC. Note that people have had issues initializing/copying files using a Mac.
August 28Aug 28 Author It's truly a new card, and I will try to copy the old one to the new one. Thank you!
August 28Aug 28 Solution If you can Telnet into the ISY, here's another process:https://wiki.universal-devices.com/ISY-99i/ISY-26_INSTEON:Replacing/Formatting_an_SD_CardI just tried this, it does work on the ISY994.
