Zooz Zwave 800LR dongle - Review
I currently only use Insteon and Zwave devices. I was using the UD Zwave/Zigbee/Matter dongle which supports Zwave 700.  Most of my Zwave devices are Zwave 800LR. I bought a Zooz 800LR dongle to replace the UD dongle.
 Zwave 800 offers greater range, lower power consumption, more memory (512kb vs 256kb), and improved security. Zwave 800 battery operated devices use less current than previous versions, receiver current is reduced up to 600% and transmission current up to 42%
1.      Removed power from the eisy
2.      Swapped out dongles
3.      Did a Zwave restore
All went well and my Zwave mesh network is up and running.
I also used a right angle USB adapter so the dongle is vertical rather than horizontal which should improve the Zwave signal
Amazon.com: Basesailor 90 Degree USB A Male to Female Adapter 4 Pack,USB 3.0 Extender | Up Down & Left Right Angle Type A Connectors,L Shape Converter for CarPlay,Printer,PS5 PS4,Laptops,Chargers,Computer,Mouse,PC : Electronics
Zwave LR is now supported, but you'll need to update IoX to 6.1 2, by enabling the staging repository in eisy-ui and upgrading.
Techman, have you got any 800LR devices to connect using LR (not mesh) using the 800LR dongle and the EISY? I use mostly Insteon, but I have a detached garage that has a separate power source. So, I thought the 800LR devices might be the answer to connect to the eisy. So, far I've updated the Zmatter dongle to the lastest firmware and updated the IoX to 6.1.2. Then I tried to add a Zooz ZEN77 S2 Dimmer using UD mobile and the QR code, but that gave me the "Long Range not supported, dongle firmware update required. 500" message. So, then I got the Zooz 800LR dongle and loaded it up and tried adding the switch through the QR code and that gave me the same message. Any ideas? Thanks.
LR is still in final testing, hopefully the final version will be released shortly. Being that LR has a range of up to a mile it should solve your communication issue with your garage
everything is work as I want. I had these pop screen it was hard to see the one behind the other. I did get it to move and it said " package update. So I did the package updates and that popup went away. Alos the one that wanted me to vaildate Zwave device is going to. But now the Nodes look like this again. But all works zooz_015.jpg
You’ve got pending updates to those battery powered devices. You’ll need to wake them and and then click on the green arrow next to each to update them.
