7 hours ago7 hr Anyone having success using OpenWeatherApp plugin with OpenWeather One Call API 4.0. I see the release notes call for One Call 3.0 - but that service is no longer available. I set up an account 3 days ago and still receive the dreaded Query Failed: 401 Message. and yes, I read the information on 401 errors at the OpenWeahter site. Ihave valid license and the latest APIkey.Any help would be appreciated - thank yoi
1 hour ago1 hr I believe that the One Call subscriptions are only valid for the specific API.The plug-in is using the One Call 3.0 API and does work with a One Call 3.0 subscription. I just verified that. I would not expect a 4.0 API key to work with the 3.0 API given all the issues I've seen and the 401 response you are seeing matches that.OpenWeatherMap has been a bit of pain for the past couple of years. I switched the plugin over to use the 3.0 API when they said the previous (2.5) API was going away. But it looks like you can still use the 2.5 API.Now they have the 4.0 API which is incompatible with the 3.0 API which means I have no good options yet again.If I leave the plugin alone and working with only the 3.0 API, anyone that gets a 4.0 subscriptions can't use it as it doesn't look like you can get a subscription to the 3.0 API anymoreIf I switch the plugin to use the 4.0 API, all existing users setup will fail until they get a new subscription and key for the 4.0 API.I'll have to give this some thought.
