September 7Sep 7 This one is a feature request by @Guy Lavoie to be able to move by percent for RTS shades.Make sure you do a full open / close and time how long it takes then put that in the span for each shade. Right now the default is 8s but my Phantom outdoor blinds are a full 27s.I also know on my Hunter Blinds I have one blind which is a laggard to the others all the time.After that you can move by percent in the up or down direction.Remember the Pending / Completed is much slower as that is a handshake with the Tahoma, not measuring when the stop signal is given.Anyway, have fun and give some feedback!## 0.0.27- RTS Move By Percent: new MOVEPCT command (percent 1–99, direction Up/Open or Down/Close) sends open or close, waits (percent × total span) / 100 seconds, then sends stop; SETSPAN sets per-shade Total Span Move Time (GV1, default 8 s, persisted); Last Command Executed adds Move By Percent; RTS-only — io/Zigbee shades keep SETPOSPS - This plugin modifies the profile, so if you are using Eisy-ui it can be harder to get it to read the profile update (the button to load profile doesn't seem to be making it happen; on the old Admin you just restart it. I am still figuring out the best way besides deleting the browser cache and restarting the service. Any ideas @bmercier or @Javi ?
September 7Sep 7 Author I have had at least once where it blasted right by the percent I had tried to move to. Wondering if the stop signal didn't get through. Let me know if anyone else sees this the odd time, I could send it twice.I must say I am enjoying this feature (use it to bring down the second shade and block morning sun) Edited September 7Sep 7 by sjenkins
September 7Sep 7 11 hours ago, sjenkins said:This one is a feature request by @Guy Lavoie to be able to move by percent for RTS shades.Make sure you do a full open / close and time how long it takes then put that in the span for each shade. Right now the default is 8s but my Phantom outdoor blinds are a full 27s.I also know on my Hunter Blinds I have one blind which is a laggard to the others all the time.After that you can move by percent in the up or down direction.Remember the Pending / Completed is much slower as that is a handshake with the Tahoma, not measuring when the stop signal is given.Anyway, have fun and give some feedback!## 0.0.27- RTS Move By Percent: new MOVEPCT command (percent 1–99, direction Up/Open or Down/Close) sends open or close, waits (percent × total span) / 100 seconds, then sends stop; SETSPAN sets per-shade Total Span Move Time (GV1, default 8 s, persisted); Last Command Executed adds Move By Percent; RTS-only — io/Zigbee shades keep SETPOSPS - This plugin modifies the profile, so if you are using Eisy-ui it can be harder to get it to read the profile update (the button to load profile doesn't seem to be making it happen; on the old Admin you just restart it. I am still figuring out the best way besides deleting the browser cache and restarting the service. Any ideas @bmercier or @Javi ?You should update the plugin to use dynamic profiles.Ref: https://developer.isy.io/docs/API/pg/DynamicProfiles
September 7Sep 7 Author 4 minutes ago, bmercier said:You should update the plugin to use dynamic profiles.Ref: https://developer.isy.io/docs/API/pg/DynamicProfilesug.
September 7Sep 7 6 minutes ago, bmercier said:You should update the plugin to use dynamic profiles.Ref: https://developer.isy.io/docs/API/pg/DynamicProfiles11 hours ago, sjenkins said:This one is a feature request by @Guy Lavoie to be able to move by percent for RTS shades.Make sure you do a full open / close and time how long it takes then put that in the span for each shade. Right now the default is 8s but my Phantom outdoor blinds are a full 27s.I also know on my Hunter Blinds I have one blind which is a laggard to the others all the time.After that you can move by percent in the up or down direction.Remember the Pending / Completed is much slower as that is a handshake with the Tahoma, not measuring when the stop signal is given.Anyway, have fun and give some feedback!## 0.0.27- RTS Move By Percent: new MOVEPCT command (percent 1–99, direction Up/Open or Down/Close) sends open or close, waits (percent × total span) / 100 seconds, then sends stop; SETSPAN sets per-shade Total Span Move Time (GV1, default 8 s, persisted); Last Command Executed adds Move By Percent; RTS-only — io/Zigbee shades keep SETPOSPS - This plugin modifies the profile, so if you are using Eisy-ui it can be harder to get it to read the profile update (the button to load profile doesn't seem to be making it happen; on the old Admin you just restart it. I am still figuring out the best way besides deleting the browser cache and restarting the service. Any ideas @bmercier or @Javi ?Cool, and thanks! I'll get it updated later today. Looking forward to trying this!2 hours ago, sjenkins said:I have had at least once where it blasted right by the percent I had tried to move to. Wondering if the stop signal didn't get through. Let me know if anyone else sees this the odd time, I could send it twice.I must say I am enjoying this feature (use it to bring down the second shade and block morning sun)But sending the stop command twice might cause the shade to go to the preset "my" position if it receives both commands, since the stop command is dual function, depending on whether the shade is moving or not. I suggest we just observe things for a little while.
September 7Sep 7 What does the ID reference, Is it necessary or could it be eliminated for a cleaner look?In UD Mobile, under custom configurtion the value can only be set using the ID number rather than open or closed
September 7Sep 7 Author 4 minutes ago, Techman said:What does the ID reference, Is it necessary or could it be eliminated for a cleaner look?In UD Mobile, under custom configurtion the value can only be set using the ID number rather than open or closedPurely a unique identifier given by the Tahoma app. Can be used to make sure you have the right device if a node name is changed independently of the unit. Its carryover from my HunterDouglas plugin where it was the only true way to know you were talking to the right shade.Clean look?!? Are you truly an Eisy user? ;)
September 7Sep 7 In UD Mobile I would like to set the icon, and icon color, depending whether the shade is opened or closed, but the value only references the ID number rather than the last command sent, i.e. open or closed. Is this a UD Mobile issue?
September 7Sep 7 Author @Techman ,It can be done: You just need to make sure the object you are doing this with {default, command, etc} is chosen as a shade (not a scene).
Monday at 05:10 PM5 days Well no...what's needed is an icon color that morphs darker or lighter in realtime as the shade closes or opens! 🤣
Monday at 06:35 PM5 days Hmm, how do I upgrade from 0.0.24? I'm trying from the dashboard, from the non-production store. It tells me it's already installed in slot 8, which is correct. But when I click on Install, nothing happens. Tried this by accessing plugins from both admin console and eisy-ui.
Tuesday at 11:10 AM5 days Author production is at v0.0.26non-production(beta) is at v0.0.27@Guy Lavoie there should be a button beside that slot 8 indicator to reinstall there. I just checked the repos & all look good.
Tuesday at 12:39 PM5 days 1 hour ago, sjenkins said:production is at v0.0.26non-production(beta) is at v0.0.27@Guy Lavoie there should be a button beside that slot 8 indicator to reinstall there. I just checked the repos & all look good.Not sure where you're referencing that button. From the dashboard I see the plugin (in slot 8) with status = connected and store = beta. If I click on Details, I see the main screen for the plugin. If I click on Update, I see that I'm running 0.0.24. See the screen shot below. If I click on Update, nothing happens. Edited Tuesday at 12:40 PM5 days by Guy Lavoie
Tuesday at 01:07 PM5 days Author Sorry, @Guy Lavoie ,What you are showing is what I was attempting to describe on my phone. I have multiple lines as I usually have local,beta, and production in three slots with different versions. Not sure what to say, the store and the GitHub look good & I am able to run 0.0.27 on beta. I will push the beta to store again. Anyone else having the issue?
Tuesday at 01:17 PM5 days 5 minutes ago, sjenkins said:Sorry, @Guy Lavoie ,What you are showing is what I was attempting to describe on my phone. I have multiple lines as I usually have local,beta, and production in three slots with different versions.Not sure what to say, the store and the GitHub look good & I am able to run 0.0.27 on beta. I will push the beta to store again. Anyone else having the issue?Well @oberkc was having a similar issue trying to update the Virtual plugin. Like I said, I know the way plugins are managed is being modified, so I thought this might be related.
