September 17Sep 17 Is it possible to adjust the width of individual columns in eisy ui with out having to widen the entire eisy-ui window
September 18Sep 18 1 hour ago, Techman said:Is it possible to adjust the width of individual columns in eisy ui with out having to widen the entire eisy-ui windowI can adjust any single column without problem. They don't seem to be sticky, when i go to another page they return to the original size.
October 2Oct 2 When you manually adjust the column width that way, another column resizes in the opposite direction in order to keep the entire grid 100% of the screen width. So this is probably not quite the ideal design, although it works well for the initial release.Ideally, you could have an option that sets each column to the largest item width plus some variable gutter width.
October 2Oct 2 The program and node data grids are scheduled to be replaced for mobile compatibility and virtualization (to fix refresh issues). Feature requests are deferred on these 2 screens until changed.
