13 hours ago13 hr The old 2413s is still functioning, but showing signs of failing. I performed a factory reset on the new 2413U. Powered down both Old PLM and EISY. Connected the new USB cable to PLM & EISY. Powered on the PLM, then powered on the EISY. Logged into Admin Console and selected RESTORE PLM. I received the error: "Failed resetting the PLM" [-200000/-30]. Unsure what to do next.
11 hours ago11 hr Author Yes. I used the cable which came with the new 2413U. It has a Type B going to the and the other end is a Type A. I am using a Type A to Type C adapter to plug it into the EISY.
11 hours ago11 hr I never performed this action but from what I've read there should be a replace modem when you plug in a different modem. If that is not present search for the procedure @Brian H post all the time.
11 hours ago11 hr If your using the admin console, click on Tools > Diagnostic > PLM info/Status. Does it show as connected? If not, replace the cableAs I remember, the 2413U doesn't ship with a USB cable. Try using a generic USB-C to USB-B cable
11 hours ago11 hr Author @Techman,The status shows: 0.0.0 v0 / Not Connected.I tried another of my USB-B to USB-A cables with my USB-A to USB-C adapter with the same result.Note that the USB-A to USB-C adapter works fine with my old PLM
11 hours ago11 hr @GPG It's most likely one of two things, the cable, or Insteon support isn't checked on the admin console configuration tab.Is the green led on the PLM on?
10 hours ago10 hr Let me know if that solved the problemIn the meantime try a different USB port on the eisy
