September 25Sep 25 I have purchase an Eisy and am waiting for it to arrive. In the meantime the Zmatter board in my Polisy just failed. I purchased an Aeotec zwave/zigbee USB dongle that I want to install in my Polisy until the Eisy arrives. Then move the Aeotec dongle to the Eisy.The Polisy has version 6.1.2. I have been searching for directions and cannot find clear steps to take. I have spent hours with AI and I cannot find a way to remove the zmatter in the software and have it look at the usb port. I have done a lot of removing and reinstalling the zmatter board and Aeotec dongle. I lost tract of what software changes and reboots that I tried through the Admin console and SSH. When the zmatter board first failed under the Zwave menu is said Zmatter z-wave is not responding. The Zigbee menu tab had all the correct tabs.Here is my current status:Zmatter board is currently removed from the polisy and the Aeotec dongle is installed.The Zwave tab says - Zmatter z-wave not responding (It is still looking for the zmatter board)The Zigbee tab says zigbee not responding (It is still looking for the zmatter board)Any help will be appreciated even sending me to the correct web page with the instructions.Thanks
September 25Sep 25 Something you could try: enter the following url on your browser:http://<your_IP_address>:8080/rest/zmatter/zwave/deactivateZMatterZWaveThis should tell the Polisy to ignore the zmatter board and revert to looking for a Zooz stick. Then plug in your Aeotec stick and reboot the Polisy. See if that helps.But back up your zwave first (under the zwave menu), though I'm not sure if that will work if the board is bad.
September 25Sep 25 Not sure about the Polisy, but for the eisy you first have to backup the zwve/zmatter dongle, then remove power and remove the zmatter dongle. Plug in the aerotec dongle and do a restore zwave/matter.If you don't have a backup of your zmatter dongle then you'll have to rebuild the zwave/matter from scratch.
September 25Sep 25 Author Thank you Guy. I have made some progress the Zigbee seems to be working but not the zwave. However, I am getting the option in the configuration tab "Migrate to Zmatter Z-Wave" That option was not visible before. Of course, the Zmatter board is not installed anymore and the Aeotec 10 pro is in the bottom USB port of my Polisy. Do you have any suggestions as to get the Polisy to look at the USB port?
September 25Sep 25 3 minutes ago, Stagehand said:Thank you Guy. I have made some progress the Zigbee seems to be working but not the zwave. However, I am getting the option in the configuration tab "Migrate to Zmatter Z-Wave" That option was not visible before. Of course, the Zmatter board is not installed anymore and the Aeotec 10 pro is in the bottom USB port of my Polisy. Do you have any suggestions as to get the Polisy to look at the USB port?It should detect the USB device automatically. On one of my test Polisys, I took out the ZMatter board that was in it, turned it into a USB dongle, and simply plugged it in. If you just plugged it in, make sure you power cycle the Polisy after.That migrate option in the Configuration tab is a default thing with the rollback to Zooz. I don't have one of the newer zwave/zigbee dongles so I don't know how it gets configured, though the release announcement for 6.1.1 said that the dongles are now "detected automatically". I don't know if that Migrate option in the Configure tab has to be clicked for that to be enabled. You could try that. You might try opening a ticket with UDI.But are you saying that zigbee is working? With the new dongle? That would indicate that the USB port is indeed working and seeing the dongle, and that it's a zwave configuration thing.
September 25Sep 25 Author Yes, the Zigbee feature of the Aeotec dongle is working. I needed to re-include a zigbee device and it was successful. There was a change in the system after I ran the command line you suggested. Before the command, the Zwave tab at the top of the Admin Console said "Zmatter Z-wave not Responding". After the command was run the Zwave tab dissapeared.Zigbee is functioningIn configuration - Matter Support is on Zigbee Support is Auto Z-Wave Support is Auto
September 25Sep 25 Zwave tab disappearing is odd. You could try setting zwave to on instead of auto in Configuration and reboot, see if that helps. Otherwise, open a ticket. The Aeotec dongle support is still new.
September 26Sep 26 Author Hello Guy Lavoie, Michel was able to fix my issue. I do not know what he did but it took a while. I think now I need to include all of my devices except the Insteon ones. Unfortunately, I have many devices and even more programs. Do you have any suggestions on how to approach including all of my devices and have them inserted into the programs with the least amount of pain possible?
September 26Sep 26 Well, if it turned out to be some kind of migration configuration or driver issue, they'll update the process to avoid whatever the issue was. You might be one of the first to go from a Zwave board to Aeotec dongle, and on a Polisy too. That will also help in keeping the Polisy alive 😊. About redefining your devices: did you have a zwave backup (and restoring didn't work)? Or you just didn't have a backup at all? The thing with the zwave backup is that there is only one file, that gets overwitten everytime you do a backup, so you can't easily try older backups. Then there's the fact that node names will usually be different for a different zwave interface. Replacing a ZMatter board with another ZMatter board would be easier. If your old device nodes are all still there in your device list, you can use search and replace in programs to adjust the programs to the new node names. It's a manual process and it's a pain, but there just are no shortcuts. And that's after having excluded and re-included every zwave device to begin with. I went through that when I went from the Zooz 700 dongle to ZMatter. Thankfully I only had about 8 or 9 devices.
September 26Sep 26 Author I don't know what the issue was but it took Michel more than 45 minutes to get the Aeotec Dongle to work. I think the problem was within the Polisy and not the dongle. I had a recent iox backup that he used and all the information is in the Admin Console but no Zwave devices work. I have been tryng to use the "Replace Failed Node" feature and that is not working ( I am probably doing it wrong). Maybe you can help me there.Here is what I am doing. For the example I am using a GE In Wall Smart DimmerFactory reset DimmerGo to Dimmer in Admin ConsoleUnder Z-Wave, select Replace Failed NodeSelect Yes to continueAt this point I am expecting a Listening for new node type of message but that does not happen.Ant suggestions?
September 26Sep 26 Hah, Like I said I have very few zwave devices, and 5 of them are locks. Still, I just thought I'd give the Replace Failed Node thing a try, and it doesn't seem to work very well... I tried it on my test Polisy that has a ZMatter dongle. I started by adding a simple zwave on/off plug in module. Then I did the Replace Failed Node command on it, which caused the related nodes to disappear. No ther messages or anything. Then I plugged in another zwave mode of the same type and pressed the link button. It linked the new module and gave it the same node names...but trying to use the node name in any program wouldn't work. I'd get nothing on the program line. Saving an reloading the program would then show "Response type 0" on the invisible line I had added. Then trying to add it again to a program shows "Set '<not specified>' DON". So that feature doesn't seem to work.The IoX backup you mention backs up programs, variable, nodes, etc but not your hardware zwave dongle data. That is done by clicking on Backup under the Zwave menu. That is meant to save the network configuration, such that you should be able to put in a new replacement dongle and then click on Restore to get back your existing zwave network. That's what I meant in my previous post about having a zwave backup. With the earlier Zooz dongle, this wasn't even offered. I initially had the Zooz dongle and when I tried the documented migration process to ZMatter, it never worked,a nd was told it indeed wasn't functional. Zwave can be a bit nasty for that.
September 26Sep 26 Author My Zwave dongle is not responding. It looks like I need to start another ticket. At this point I'm pretty frustrated. It's time to walk away and take a break. Thanks for your help. I will update you with the final outcome.
October 5Oct 5 Author Yes, there has been much progress. Michel dedicated a significant amount of time logged into my computer. I really appreciated his help. It was above and beyond my expectations.Here is the result: We learned that my original Zmatter board was not bad after all and I ended up re-installing and using it. In a separate issue , we learned that there is much difficulty migrating to the Aeotec 10 Pro stick. I am returning it. We discovered that some of the issue was that information was not being displayed in the Admin Console (Java base version) but was displayed correctly in the Eisy-UI console. The Admin Console is going away so there was no reason to spend time fixing the software. I personally was not familiar with the Eisy-UI console but now I am using it exclusively and getting familiar with it.All the best.
October 5Oct 5 Interesting. So UDI has determined that migrating from ZMatter to Aeotec is currently problematic, and hopefully will be reviewed. It reminds me of the similar issue going from the original Zooz dongle to ZMatter, which I never got to work. Btw, what originally had you thinking the ZMatter board was bad (in case someone else comes across a similar problem)?
October 6Oct 6 @Stagehand ,I'm in a very similar boat with the Aeotec 10 Pro Stick. Which firmware did you test with?Z-Stick 10 Pro Update - Z-Wave (Firmware V2.0 SDK 7.23.2)has two versions 7.23.2 and 7.24.2. I went straight to the 7.24.2 version (being the newest) with the results:ADMIN CONSOLE throws NODEDEF errors and is now useless for programming (picker failures, etc)System Restores, Resets, Clean Starts will not resolve AC errorsI was able to apply 7.23.2 over 7.24.2 but have yet to test that FWBOTTOM LINEIf you want/need Admin Console to remain functional,DO NOT attempt a dongle topology change on your production systemUntil YOU have done a proper Hardware Qualification Test !
October 7Oct 7 Author I tried to follow what Michel was doing but the code is beyond my understanding. I don't know if there was an official determination that there is an issue with migrating Zmatter to Aeotec. However, early on we thought that the Zmatter board was bad. I always felt that the problem with the Zmatter board was a software issue that stopped the Zwave and Zigbee from communicating but I bought the Aeotec dongle just to be safe and have an alternative device. We installed the Aeotec Dongle, late on a Friday. Most everything was working by the end of the day. The next morning the Zwave and Zigbee stopped communicating. After working with the Aeotec dongle for a while, we switched back to the Zmatter board and everything worked. We determined that if I wanted to use the Aeotec dongle, I would have to include all of my devices from scratch. Having 40+ devices, I decided to keep the Zmatter board. I don't think that I would have noticed any advantages between the 700 and 800 series Zwave features.
October 7Oct 7 @Stagehand,I'm wondering what firmwares are on the Aeotec dongle you attempted with? Was it deployed straight out of the box or did you go through the SILABS Z-Wave and/or Tera Term Zigbee updates?The Zigbee update process was very problematic due to the bootloader switch. I ended up disassembling the dongle to be able to actuate it reliably during insertion.Pro Tip: Remove the metal shield from the body first, it locks the 2 plastic halves together!During limited initial testing, there was a serious improvement in both speed and reliability with my reincluded 800s (star) in a very challenging and noisy environment. I appreciate you not wanting to reinclude and reprogram for 40 Z-Waves, not a fun endeavor! I'm staring down 85 hard wired and another 50 batts so ya, not fun...
October 7Oct 7 3 minutes ago, BigMojo said:I appreciate you not wanting to reinclude and reprogram for 40 Z-Waves, not a fun endeavor! I'm staring down 85 hard wired and another 50 batts so ya, not fun...I had only about 8 or 9 zwave devices that I had to re-include when I switched from the Zooz dongle to ZMatter, so I understand the trepidation. Then there's updating all the program references to the new nodes. Ugh.I guess the watchword is: get a spare dongle of the same type you're using, if available!
October 7Oct 7 Exactly, if available! The ZMatter dongle is discontinued so I'm not going to rebuild with either of mine. They've both been through lightning strikes, one had its eISY absolutely smoked, so there's no way I'm devoting any real time to equipment that isn't procurable.
October 7Oct 7 28 minutes ago, BigMojo said:Exactly, if available!The ZMatter dongle is discontinued so I'm not going to rebuild with either of mine. They've both been through lightning strikes, one had its eISY absolutely smoked, so there's no way I'm devoting any real time to equipment that isn't procurable.Others might be interested in yours as spares.
October 8Oct 8 Author 20 hours ago, BigMojo said:@Stagehand,I'm wondering what firmwares are on the Aeotec dongle you attempted with?Was it deployed straight out of the box or did you go through the SILABS Z-Wave and/or Tera Term Zigbee updates?The Zigbee update process was very problematic due to the bootloader switch. I ended up disassembling the dongle to be able to actuate it reliably during insertion.Pro Tip: Remove the metal shield from the body first, it locks the 2 plastic halves together!During limited initial testing, there was a serious improvement in both speed and reliability with my reincluded 800s (star) in a very challenging and noisy environment.I appreciate you not wanting to reinclude and reprogram for 40 Z-Waves, not a fun endeavor! I'm staring down 85 hard wired and another 50 batts so ya, not fun...I didn't notice the firmware version on the Aeotec Dongle, but I used it straight out of the box. It has already been returned.
