Trying to add an analog node.
Hi,
I just received the WebControl 8 today and am trying to add an analog node but can't seem to create the node. I included a screen shot of my configuration. Would apricate any suggestions. Thanks.
Log included.
New Text Document (2).txt
Edited by garybixler
Add log
Hi Gary,
From your screenshot it doesn't look like there is a space between the colon and the next exclamation. Try this
"Aip1": "Light Level"
Tim
@garybixler also I wanted to mention if you have a lot of nodes you want to add, use chat get, feed it all of your nodes and ask it to format for Json single line. That way you can copy it and paste it into web control plug in.
@TJF1960 Thanks for the reply. I just tried variations of "aip1": "light Level" but still cant get it to add a node.
"Aip1": "Light Level" "aip1": "Light Level" "Aip1" : "Light Level" "aip1" : "Light Level"
"AIP1": "Light Level"
@garybixler Yes, doggone it. I forgot about the parenthesis, I am sorry. You were persistent and got it going.
If you wouldn't mind, after you play with it for a while, let me know what you think of the plugin.
Tim
@TJF1960 Initially I thought what was in the parenthesis was to show what need to be configured. I had tried the parenthesis earlier but I didn't have the space between ": " . Thanks for pointing that out.
