October 12Oct 12 Not a new user per say but ever since my z-wave dongle on the old ISY944 died in Feb its been a struggle to get my Z-wave network backup and running. After finely getting an Aeotec Z-Stick 10 pro connected to my new EISY I manged to connect the basic devices but the last couple of devices I added are showing all of the available parameters under the main table but when I try to look for the parameters in a condition section of the program they are simply not available for use.This is a Honeywell T6ZW thermostat When I try to access for instance the "Mode" parameter to trigger a program action (adding it to the Condition section), the ZY013 Thermostat does not even show up to pick any options. Only the power Alarm is there.However under the Actions section the ZY 013 Thermostat parameters show up??I have done multiple Z-Wave Synchronizations and Heals nothing changes. This was never an issue in the ISY44. So far its been 10 months and I have not been able to restore my original zwave functionality to what I had in the old ISY944. The mode setting previously was used to trigger several program in the ISY944. Any insight on this would be appreciated.
October 12Oct 12 I noticed that you have pending writes for Z09, are there any other pending writes for your Zwave devices. You should clear up all of the pending writesYou have some of your programs disabled which may be preventing the display of all the device nodes.
October 13Oct 13 15 hours ago, UDFU_2019 said:Not a new user per say but ever since my z-wave dongle on the old ISY944 died in Feb its been a struggle to get my Z-wave network backup and running. After finely getting an Aeotec Z-Stick 10 pro connected to my new EISY I manged to connect the basic devices but the last couple of devices I added are showing all of the available parameters under the main table but when I try to look for the parameters in a condition section of the program they are simply not available for use.This is a Honeywell T6ZW thermostatWhen I try to access for instance the "Mode" parameter to trigger a program action (adding it to the Condition section), the ZY013 Thermostat does not even show up to pick any options. Only the power Alarm is there.However under the Actions section the ZY 013 Thermostat parameters show up??I have done multiple Z-Wave Synchronizations and Heals nothing changes. This was never an issue in the ISY44. So far its been 10 months and I have not been able to restore my original zwave functionality to what I had in the old ISY944. The mode setting previously was used to trigger several program in the ISY944. Any insight on this would be appreciated.Does the same happen in eisy-ui (Beta)? It is difficult to see from your screen shot as there are still items in the scroll list, but it stopped at ZY 013 Power Alarm which is alphabetically before ZY 013 Thermostat.
October 18Oct 18 Author Thanks for the responses, so I have removed all disabled programs, cleared to pending writes to any devices. As for EISY-UI currently I have no program information, the programs are listed but every line in the program reports "error loading Data". I have now also discovered that I have a command for an insteon I3 Paddle switch in in a program and working but if I try to replicate the command its not available, same as the Zwave issue. Edited October 18Oct 18 by UDFU_2019
October 18Oct 18 Error loading data would be a n issue. This could likely cascade to other things.Please share a screenshot of the firmware version from eisyui. So we can verify eisy is on the latest firmware.
October 19Oct 19 Author Had to create a new topic as this one would not let me paste any more screen shots into it. The new topic is Z-WAVE Device Parameters Unavailable to program P2.I have done all my package updates, and several reboots, made sure this is the only device in the account.
October 19Oct 19 Please open a ticket, with a link to the post and your UUID. Authentication issues are not conducive to public debuging.
