October 14Oct 14 I want to copy the txt of a program in web ui, >>> in AC, select the program, right click, copy to clipboard ( as per below ) ? Also ... will Generate Topology be an option in web ui ?Weekend - [ID 0070][Parent 0001] If On Sat, Sun Then Run Program 'abc' (Then Path) Else - No Actions - (To add one, press 'Action')
October 30Oct 30 I will bump this too. Also, no drag and drop function for moving programs into folders.
Tuesday at 06:57 PM2 days @Javi Sorry, I don't want to seem to harass, just curious if Copy to Clipboard and Generate Topology are on the roadmap for eisy-ui? I haven't seen topology mentioned any where but this thread.Thank you,-Tim
Tuesday at 09:50 PM2 days Solution Implemented see: https://wiki.universal-devices.com/Eisy-ui#Programs
Wednesday at 12:36 AM2 days @Javi My observations: Issues with this as it stands is there are a lot of moving your mouse around and clicking multiple times. Might I suggest that copy (making a duplicate program) is its own button separate from copy to clipboard. And I would only do copy to clipboard. I don't understand why it says it needs https to copy to clipboard and why that is greyed out. the page is running in https. But copy to clipboard is the only feature anyone would want. Copying to some file that ends up on your drive would never be the goal, you would have to then open that file and copy it again to wherever it is you actually wanted it to be. Copy to json could have use if there were something to import it into that wanted in that format, but I don't know what that is. Perhaps you have something in the works?
Wednesday at 06:41 PM1 day 18 hours ago, apostolakisl said:@JaviMy observations:Issues with this as it stands is there are a lot of moving your mouse around and clicking multiple times. Might I suggest that copy (making a duplicate program) is its own button separate from copy to clipboard. And I would only do copy to clipboard. I don't understand why it says it needs https to copy to clipboard and why that is greyed out. the page is running in https. But copy to clipboard is the only feature anyone would want. Copying to some file that ends up on your drive would never be the goal, you would have to then open that file and copy it again to wherever it is you actually wanted it to be. Copy to json could have use if there were something to import it into that wanted in that format, but I don't know what that is. Perhaps you have something in the works?These are limitations when running in a browser, if it is grayed out it is not a valid cert, use through my.isy.io. So this must remain for these cases as it is easy to debut your issue and also gives you another option.Also this has always been confusing to many users, this simplifies for all.
Wednesday at 07:53 PM1 day 51 minutes ago, Javi said:These are limitations when running in a browser, if it is grayed out it is not a valid cert, use through my.isy.io. So this must remain for these cases as it is easy to debut your issue and also gives you another option.Also this has always been confusing to many users, this simplifies for all.I don't understand why the need for all the pop-ups and confirms. As troublesome as the java ad con is, it is much faster and simpler for so many things. Every time I start using the new eisy ui console I get frustrated by the unnecessary steps and delays and go back to using java. Just do right click, whatever, done. All of the confirms and acknowledge popups that are halfway across the screen serve no purpose. In the old ad con I can disable AND then reenable a program faster than just disabling OR enabling in the new. If it is big deal item that isn't readily reversible, I get it. The eisy ui has you moving your mouse all over the place back and forth clicking multiple times to complete simple tasks not scary blow the whole thing up by accident tasks. Similar story with enabling/disabling a program. Eisy-ui ->Right click/enable./mouse half way across the screen/OK/OK/mouse back across screen to where you were working. Why not just right click/enable. . .done? Regarding confusion of copy. Call it 1) Duplicate Program and 2) Copy to Clipboard. Right click and have these choices directly.
Wednesday at 08:16 PM1 day Some confirmation dialogs have been removed in the latest release. This case is different.These things are a personal preference, not universal to all users, especially new users. Why are there 3 copy buttons? Because less than 1% of users want a clipboard option, and ~3% may copy a program to display for future use or forum use. The argument to remove the option is greater than the argument to keep the option.So this dialog serves a legitimate propose. (1) If local clipboard will not work, we have no control over this, it is browser security. So we need to provide another method for local users, while giving a reason clipboard does not work. The alternative, which was almost implemented was to remove copy to clipboard all together, but we would have been having the same conversation.(2) Admin has 3 different ways to copy programs, in different locations, all confusing to new users. It is now consolidated to a single location. (3) Context menus do not work well in mobile and are actively discouraged in modern development due to discovery issues. So these commands need to be moved to buttons but we cannot replace each context menu item with a button as mobile also has less space for this.
12 hours ago12 hr @Javi Happy Thanksgiving!Can I suggest this:If copy to clipboard is greyed out, then you would be forced to use copy special with the full menu. Perhaps in the copy special section you include a dialogue window that explains why copy to clipboard would be greyed out. The copy special name is in keeping with ms excel paste special.I think the terminology "duplicate program" is concise and unambiguous compared to "copy".In addition, drag and drop sure would be nice.It would also be nice to have a select multiple. Since html doesn't let you ctrl-click multiple things, you need to trigger a box of check boxes next to items and then you can then select multiple to complete an action on. Example is unifi screenshotted below. You see the manage button at the bottom, clicking that opens check boxes next to each item where you can select multiple and take an action.I'm not sure if you have looked at unifi console, but it is functioning very much like eisy. It is a local piece of hardware that you can connect to directly or you can connect through a portal. The console runs in a web browser. Like eisy, it has a lot of complexity in its configuration. While I find fault with it in places, I think it does a pretty good job with a pretty complex situation. Edited 12 hours ago12 hr by apostolakisl
