October 16Oct 16 "/ Not Connected"IoX works - but I cannot control anythingUD Mobile cannot get the status of any deviceTried unplugging both eisy and plm, plug plm back in and then restart eisy - no change.
October 16Oct 16 Was anything changed? If not then likely a PLM faulure.Also verify Insteon is enabled in eisy-ui > Menu > Protocols > Insteon
October 16Oct 16 Author The only thing I did was from IOX to "restore device" on a slave switch for a 3-way circuit. The Off from the master was not showing off on the slave. This 3 way circuit was installed over 7 years ago, I cannot believe that I never noticed this before. But the "restore device" actually fixed that.That was it. But then it was insane. I tried so many things but eventually a hard reset on the PLM and yet another reboot on eisy. From there I could see the PLM from IOX and UD Mobile was showing the status of all items. Relatively new USB PLM too. The only thing that's odd and that I get on any computer running IOX is that if I do: Tools --> Diagnostics --> PLM Info/Status - this runs a little window like the "linking" window that runs from 1% to 100% and just continues forever. I don't know what it's doing if anything. I cannot remember looking at the PLM Info/Status for many years so no idea when this started but curious if anyone else has seen this on IOX?I woke up and saw that none of the programs ran over night.On UD Mobile, I clicked the "Insteon" option on UD-Mobile - (Settings Insteon) but I was afraid that was going to reset everything and although I had a backup I didn't want to go down the path if possible. Edited October 16Oct 16 by raymondjiii
October 16Oct 16 9 minutes ago, raymondjiii said:The only thing I did was from IOX to "restore device" on a slave switch for a 3-way circuit. The Off from the master was not showing off on the slave. This 3 way circuit was installed over 7 years ago, I cannot believe that I never noticed this before. But the "restore device" actually fixed that.That was it. But then it was insane. I tried so many things but eventually a hard reset on the PLM and yet another reboot on eisy. From there I could see the PLM from IOX and UD Mobile was showing the status of all items. Relatively new USB PLM too. The only thing that's odd and that I get on any computer running IOX is that if I do: Tools --> Diagnostics --> PLM Info/Status - this runs a little window like the "linking" window that runs from 1% to 100% and just continues forever. I don't know what it's doing if anything. I cannot remember looking at the PLM Info/Status for many years so no idea when this started but curious if anyone else has seen this on IOX?I woke up and saw that none of the programs ran over night.On UD Mobile, I clicked the "Insteon" option on UD-Mobile - (Settings Insteon) but I was afraid that was going to reset everything and although I had a backup I didn't want to go down the path if possible.Ok, it is not clear if the issue persist
