Change background and colors on eisy-ui
I find the background (black) and the general color scheme of eisy-ui to be almost unworkable. In my case, I have lighting, sunlight,
and dust problems on the screen which make many of the items unreadable... in addition some of the text are of colors that don't work well on a black background.
Is there a way to change the color scheme?
2 hours ago, EricBarish said:
Under eisy-ui -->settings --> display you get a choose of light (black letters on white background) or the current white text on back
And where are the settings? I assume that might be a solution, but I could never find the settings although they may be in that black mess.
For @bmarsh ---- @EricBarish told you where in the section you quoted
Access the menu by clicking on the three bars at the top left of eisy-ui. Settings is the second option from the bottom. Display is the third tab (the rightmost one at the top of the screen). Presumably you want to chose Light (bottom radio button) or System Default (top radio button).
