Sunday at 12:35 AM2 days Hi,I'm brand new to IoX and node servers, so please bear with me! I'm trying to get AVRemote working reliably with my Marantz SR6011, and would appreciate some guidance.My setupController: eisy / IoX 6.0.5Polyglot PG3x: 3.4.18Node server: AVRemote 2.0.18 (Free/Production)Receiver: Marantz SR6011Receiver IP: 192.168.1.105Connection: TCP port 23Receiver's Network Control setting: Always OnAVRemote's Connect On Demand setting: trueWhat happensAVRemote initially showed the receiver as off even when it was on.Changing Connect On Demand from false to true and restarting AVRemote improved power-status reporting. It now correctly shows the receiver as on.Volume readings have sometimes appeared incorrect, but subsequently matched the receiver after I changed the volume at the receiver itself.Commands from IoX are unreliable. Set Volume and Input have not produced the expected changes at the receiver. Mute has worked intermittently.Responses and status updates can be slow.Relevant log errorsThe latest debug log contains:ConnectionRefusedError: [Errno 61] Connection refusedThis occurs when AVRemote attempts to connect to 192.168.1.105:23 to send a volume command.It also contains:OSError: [Errno 9] Bad file descriptorThis occurs during recv() while AVRemote is polling receiver state, including Zone 3.The logs also show some successful communication—for example, AVRemote sends SI? and receives SISAT/CBL—so communication is not failing consistently.What I've triedVerified the receiver IP address and port 23 in AVRemote configuration.Confirmed Network Control is set to Always On.Changed Connect On Demand to true and restarted AVRemote.Restarted AVRemote and tested Power, Volume, Input, and Mute controls.Downloaded fresh debug and Polyglot log files.I have attached the latest debug log package.Could these errors indicate a connection-management or concurrent polling issue in AVRemote's Denon/Marantz driver? What would you recommend trying next?Thanks for your time and for maintaining AVRemote. I'm happy to follow step-by-step instructions, but I'm not experienced with command-line troubleshooting. AVRemote_10-24-2026_52456_PM.zip
13 hours ago13 hr Seems like your receiver just doesn't respond to Zone3 commands. Do you have zone3? If you do, you can shut off AVRemote and just connect via telnet cmd line and try running some of Z3 commands. See what you get as a response.
1 hour ago1 hr Author Thanks for the response. My receiver is configured as a 7.1.2 Atmos system, with all nine internal amplifier channels assigned to the Main Zone. I checked Marantz's documentation, which indicates that the SR6011 does not support Zone 3.Since the SR6011 supports the Main Zone and Zone 2, but not Zone 3, could you confirm which zone commands AVRemote is sending? Is it issuing Zone 3 commands as part of its normal initialization or status polling, even though the receiver doesn't support Zone 3?
