October 26Oct 26 I have been trying to update packages so that I can start using the new eisy-ui. Here is the message I get when starting the process. However, the system comes back right away and says packages are up to date but no eisy-ui. When I try again, I get the same message.
October 26Oct 26 If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system. Instead:Back up your IoX and PG3Reflash your eisy using our USB reflash stick
October 28Oct 28 I just did an upgrade packages to the current staging release and my eisy seems bricked. I assumed the system would tell me if I had an old OS, I’ve kept everything pretty up to date. I don’t have a USB reflash stick and I can’t wait for one to be delivered. How can I create my own?
October 28Oct 28 8 minutes ago, photogeek54 said:I just did an upgrade packages to the current staging release and my eisy seems bricked. I assumed the system would tell me if I had an old OS, I’ve kept everything pretty up to date. I don’t have a USB reflash stick and I can’t wait for one to be delivered. How can I create my own?Open a ticket, An alternative fix would be for UDI to allow you to download an installation image to your own stick and reflash the eisy that way,
10 hours ago10 hr I think I am bricked as well. Was on 6.0.4, hit upgrade, waited, then it said reboot, I did. Now no access.Also my last backup is from 5.8.4 - hopefully this will be able to be used.Submitted ticktet.Any advice?
