Serious Issues migrating nodes
Hi
I migrated two differnt nodes (VUE and DSC) to the new nodes (Hoping the eisy-ai would be able to see them)
However, the migration looked ok, but they nodes are no longer running. to make it worse, I cannot delete the migrated node and install the original one as eisy-ui still holds the slot
I had no issues moving nodes I created my self
It seems somehow one of the nodes recovered after multiple restats, but the other still hold the slot (VUE) and I will not run without errors - I seem to recall thisnode required developer libraries to be installed when I installed iy initially
Edited by Panda88
I found another (minor) issue - when migrating as a developer it does not seem to pick the latest version released (so it installs an older version) - maybe it should refresh node store before migrating
Also, the store entry does not seem to update teh text inteh readme.md files etc
Edited by Panda88
I can see this working for new nodes - I am really having a hard time with existing nodes - I create a develpoment node of my existing node, but when I want to run it in place of the installed node, I will owerwrite the existing node - I do not event want to think about how to publish the changed node as a new version of the existing node. I hope you will keep legacy - it is a lot easier to deal with
