Humidity sensor problem
Hi,
I first got the HIH-4021-003 from Digi key and accidently installed it backwards and it absolutely burnt up. Next I correctly installed an HIH-4000-002 from eBay and it to burnt up. Waiting for the second HIH-4021-003 from Digi Key to try but I can see the problem with the first sensor but the second one should have worked. Am I using the wrong sensors? I doubled checked the voltages from the Webcontrol8 and they look fine. Thanks for any thoughts.
Gary
I think I am finding that the pinout for the HIH-4021-003 is different than shown in the manual. I am seeing pin 1 as ground, pin 2 as out and pin 3 V.
Gary
Its been a while since I used the humidity sensor. Surprised it burned out even if you connected incorrectly. Check to make sure you have 5 volts between V+ and V- on the web board with nothing connected. . Here is link to the data sheet for this device. Spec says something about a 80 ohm load between Data and V-, i think this is allready on the web board, you check with a volt meter with no power to the board and see what you get. Those chips are expensive, I remember getting them for a few dollars. I checked but can npot find the spares i purchased.
Eric
https://static.datasheets.com/doc/13022347-honeywell-hih-4021-003-ds.pdf
