Thursday at 07:36 PM2 days @bmercier I tried the z-wave backup function, but it doesn't seem to ever finish. I presume it should complete in a matter of seconds - mine just spins and spins,I am using the UD z-wave dongle.However clicking anywhere on the display clears the Backup popup.It is reproducible, I have not tried a reboot at this point.
Thursday at 07:37 PM2 days Just now, mmb said:@bmercier I tried the z-wave backup function, but it doesn't seem to ever finish. I presume it should complete in a matter of seconds - mine just spins and spins,I am using the UD z-wave dongle.However clicking anywhere on the display clears the Backup popup.It is reproducible, I have not tried a reboot at this point.It can take minutes.1 minute ago, mmb said:@bmercier I tried the z-wave backup function, but it doesn't seem to ever finish. I presume it should complete in a matter of seconds - mine just spins and spins,I am using the UD z-wave dongle.However clicking anywhere on the display clears the Backup popup.It is reproducible, I have not tried a reboot at this point.Also make sure to run version >= 1.4.8
Thursday at 09:33 PM2 days Author 1 hour ago, bmercier said:It can take minutes.Also make sure to run version >= 1.4.8Thanks Eisy is up to date, 1.48.Tried it again, doesn't seem to finish and restore fails as well.Maybe I should reboot? Edited Thursday at 09:35 PM2 days by mmb
Friday at 12:11 AM2 days 2 hours ago, mmb said:Thanks Eisy is up to date, 1.48.Tried it again, doesn't seem to finish and restore fails as well.Maybe I should reboot?Likely the process is finishing, but for some reason the UI is not being updated.First reboot eisy, wait at least 5 minutes, so we start from a cleans state.Run the backup, if it does not finish in 30 secondds click out of the dialog. Download the Zwave LogDownload the Event Viewer Log, from the Event Viewer Tab (this is the UI's log, must be done before any refresh).Attache logs to a ticket for investigation
Friday at 01:56 PM1 day Author 13 hours ago, Javi said:Likely the process is finishing, but for some reason the UI is not being updated.@Javi I checked the Z-wave log, it successfully finishes, but as you said it's just the UI isn't being updated.[2026-10-30 07:42:29.687] [I] [iox] ZWAVE-WORKQ-35 Queue backup ZMatter Z-Wave dongle[2026-10-30 07:42:29.687] [I] [iox] ZWAVE-WORKQ-35 Start backup ZMatter Z-Wave dongle[2026-10-30 07:42:29.687] [I] [zddx_operations] Saving configuration one file data[2026-10-30 07:42:29.701] [I] [iox] ...backupZWayDongle - Reboot dongle[2026-10-30 07:42:29.701] [I] [...] Adding job: Soft reset[2026-10-30 07:42:29.707] [I] [iox] ZWAVE-WORKQ-35 Finished backup ZMatter Z-Wave dongleDo you still want a ticket?
Friday at 03:05 PM1 day 1 hour ago, mmb said:@Javi I checked the Z-wave log, it successfully finishes, but as you said it's just the UI isn't being updated.[2026-10-30 07:42:29.687] [I] [iox] ZWAVE-WORKQ-35 Queue backup ZMatter Z-Wave dongle[2026-10-30 07:42:29.687] [I] [iox] ZWAVE-WORKQ-35 Start backup ZMatter Z-Wave dongle[2026-10-30 07:42:29.687] [I] [zddx_operations] Saving configuration one file data[2026-10-30 07:42:29.701] [I] [iox] ...backupZWayDongle - Reboot dongle[2026-10-30 07:42:29.701] [I] [...] Adding job: Soft reset[2026-10-30 07:42:29.707] [I] [iox] ZWAVE-WORKQ-35 Finished backup ZMatter Z-Wave dongleDo you still want a ticket?Someone else submitted one. Are you using the staging build? This had firmware (IoX) component currently in staging.
Friday at 03:33 PM1 day Author 25 minutes ago, Javi said:Someone else submitted one. Are you using the staging build? This had firmware (IoX) component currently in staging.Just the Beta 1.48, the release note about changes in the z-wave backup prompted me to try it out.
Friday at 03:55 PM1 day Ok, I think it was pushed to beta before the required firmware update. Backup completes, the UI dialog will not update until firmware is updated.
Friday at 03:59 PM1 day Author 3 minutes ago, Javi said:Ok, I think it was pushed to beta before the required firmware update. Backup completes, the UI dialog will not update until firmware is updated.Should I update using staging or wait for the Beta (still 1.48 for me).
Friday at 05:14 PM1 day Author 32 minutes ago, Javi said:whatever you like, currently the only thing broken is the dismiss.Works fine now, thanks!
