Tiles Not Showing Status Indicators on Startup
I'm experiencing an issue with customized tiles on my Favorites screen in UD Mobile.
I have customized tiles set up for the following functions:
  • Disarm the alarm.
  • Arm the alarm.
  • Display the current alarm status.
The issue I'm experiencing is with the Arm and Disarm tiles.
When I first open UD Mobile, the Arm and Disarm tiles do not display the small circle indicator in the upper-left corner of the tile.
However, if I select the tile and then navigate back to the Favorites screen, the circle indicator appears as if its now synced.
Once that indicator appears, selecting either tile runs the program, either arming or disarming the alarm.
After the indicator appears, it remains visible even if I navigate through other menus and return to the Favorites screen. The functionality continues to work as expected.
The issue only returns after I completely close UD Mobile and reopen it. I then have to go through the same process again to get the indicators to appear.
My question is: Is this a known issue with UD Mobile, or is there a setting or configuration I'm missing? It almost seems like the app isn't refreshing or initializing the status indicators for these customized tiles when it first launches.
Any suggestions or insight would be appreciated!
