November 3Nov 3 I needed to enable, write some changes, then re-disable a number of nodes. There was a lot of useless busy work. right-click, hit enable . . . should be done. Instead you got a popup in the middle of the screen that you have to swipe your cursor way over to confirm you want to enable, then there is another popup announcing it is enabled that you have to click out of even further over. None of that is needed. Just right click, enable and be done with it. It is an easily reversed thing if you did it by accident and you don't need a popup confirming it because you get the red mark next to the node immediately. The java console is far better for this at present. I also then had to click on each node and swipe way over to the right menu to write changes. You should be able to do this also with just a single right click, write changes, like in Java.These were all devices I use for Christmas lights. Writing these changes now was only necessary because of the annoying messages every time you log in and then they hang out blocking the lower right of the screen. I don't think any of these messages are needed at all. The yellow dot next to the node is plenty. Edited November 3Nov 3 by apostolakisl
