November 5Nov 5 @bob123 wrote:"Hopefully will get some time this weekend to attempt the migration from polisy to eisy and just moving the zooz dongle is all I need to do."Bob,How did it go?I am in the same situation, and with an older Polisy that will not go beyond 5.4.4 without a system OS reflash, and a 700 series USB ZWave stick, it is the latter that is the big hold-up, as you know there is no backup option. Reportedly ( @Guy Lavoie ) unplugging, and plugging it into a (new) replacement Eisy may work. I also have some polyglot 3.0 stuff that will have to get moved.I had another Polisy (cottage) that was a simpler setup, and no Z-Wave, which I did reflash, and it bricked at first. Was eventually able to get it going again with multiple reboots and some SSH twiddling - so a little gun-shy. It sits at 5.8.0.I am concerned that after December I will lose access to my systems through the java applets. A bit frustrating as everything is working perfectly, and happy with the app. Unhappy with potentially having to spend a bunch of money (for an Eisy) and a bunch of time, and will essentially end up with the same functionality.Orest Edited November 5Nov 5 by oskrypuch
November 5Nov 5 I didn’t get a chance to attempt the migration yet. My feeling is that since the zwave stick records the zwave associations internally, it should maintain connections when it’s moved. I’m hoping the zwave nodes are in the general backup and simply resume working. i think you should be okay after December with the Java front end- it’s not being turned off.
November 5Nov 5 Solution 1 hour ago, bob123 said:i think you should be okay after December with the Java front end- it’s not being turned off.That's right, if you don't upgrade that Polisy and leave it as it is, admin console will keep working as it always has.
November 7Nov 7 Author On 11/5/2026 at 2:28 PM, bob123 said:I didn’t get a chance to attempt the migration yet..... Well, do drop by and post, when/if you get around to it.Orest
November 16Nov 16 Orest,Upgraded yesterday. Backed up polisy and PG3. Put the new eisy on the network with no plm or zwave dongles, upgraded it and restored only the polisy backup. Made sure in the configuration tab that Insteon and zwave were on.It was functioning fine both from the Java app and eisy-ui.I then shut it down using the front panel button. Powered down polisy. Moved the zooz zwave stick and plm from the polisy to the eisy. Powered eisy back on. Very happy- both Insteon and zwave worked perfectly without any adjustments. And that is with very finicky zwave locks. Pg3 and node servers took several hours of reloading, reinstalling and configuration. Did the restore from backup. None of the custom configuration parameters are restored with the backup. You have to essentially setup each node server from scratch. Once running, the nodes lined up correctly with programs. Java console functions well as does the new eisy-gui.Let me know how your upgrade goes.
