November 5Nov 5 @bob123 wrote:"Hopefully will get some time this weekend to attempt the migration from polisy to eisy and just moving the zooz dongle is all I need to do."Bob,How did it go?I am in the same situation, and with an older Polisy that will not go beyond 5.4.4 without a system OS reflash, and a 700 series USB ZWave stick, it is the latter that is the big hold-up, as you know there is no backup option. Reportedly ( @Guy Lavoie ) unplugging, and plugging it into a (new) replacement Eisy may work. I also have some polyglot 3.0 stuff that will have to get moved.I had another Polisy (cottage) that was a simpler setup, and no Z-Wave, which I did reflash, and it bricked at first. Was eventually able to get it going again with multiple reboots and some SSH twiddling - so a little gun-shy. It sits at 5.8.0.I am concerned that after December I will lose access to my systems through the java applets. A bit frustrating as everything is working perfectly, and happy with the app. Unhappy with potentially having to spend a bunch of money (for an Eisy) and a bunch of time, and will essentially end up with the same functionality.Orest Edited November 5Nov 5 by oskrypuch
November 5Nov 5 I didn’t get a chance to attempt the migration yet. My feeling is that since the zwave stick records the zwave associations internally, it should maintain connections when it’s moved. I’m hoping the zwave nodes are in the general backup and simply resume working. i think you should be okay after December with the Java front end- it’s not being turned off.
November 5Nov 5 1 hour ago, bob123 said:i think you should be okay after December with the Java front end- it’s not being turned off.That's right, if you don't upgrade that Polisy and leave it as it is, admin console will keep working as it always has.
November 7Nov 7 Author On 11/5/2026 at 2:28 PM, bob123 said:I didn’t get a chance to attempt the migration yet..... Well, do drop by and post, when/if you get around to it.Orest
November 16Nov 16 Solution Orest,Upgraded yesterday. Backed up polisy and PG3. Put the new eisy on the network with no plm or zwave dongles, upgraded it and restored only the polisy backup. Made sure in the configuration tab that Insteon and zwave were on.It was functioning fine both from the Java app and eisy-ui.I then shut it down using the front panel button. Powered down polisy. Moved the zooz zwave stick and plm from the polisy to the eisy. Powered eisy back on. Very happy- both Insteon and zwave worked perfectly without any adjustments. And that is with very finicky zwave locks. Pg3 and node servers took several hours of reloading, reinstalling and configuration. Did the restore from backup. None of the custom configuration parameters are restored with the backup. You have to essentially setup each node server from scratch. Once running, the nodes lined up correctly with programs. Java console functions well as does the new eisy-gui.Let me know how your upgrade goes.
9 hours ago9 hr Author On 11/16/2026 at 8:56 AM, bob123 said:Orest,Upgraded yesterday. ....@bob123 Thanks so much for the reply!!And, that is very encouraging. I think your post should be pinned somewhere, as there are likely others in the very same situation, and our config upgrade is not well addressed in the otherwise detailed docs and wikis!I'm not surprised about the PG3 issues, but delighted to hear that the 700 dongle and ZWave behaved so well.Orest Edited 8 hours ago8 hr by oskrypuch
8 hours ago8 hr Author @bob123 .... one other question. I have the USB PLM, and that and the 700 Zwave dongle are both accomodated with the two USB ports on the Polisy.From the specs, looks like the Eisy Lite has a USB-C and two of USB 3.0, and one USB 2.0.Which of the 3.0/2.0 USB ports did you use? I wonder if it matters. Some older devices don't like USB 3.0.Orest Edited 8 hours ago8 hr by oskrypuch
8 hours ago8 hr @oskrypuch I checked on which ports I used. Did not choose which ports to use for any good reason - just plugged into the easiest ones to reach.Zwave stick. Plugged into the 2.0 rear slot. I do have it on a right angle usb adaptor so the stick is vertical.PLM cable. Plugged into the middle 3.0 slot.
7 hours ago7 hr Author 2 minutes ago, bob123 said:@oskrypuchI checked on which ports I used. Did not choose which ports to use for any good reason - just plugged into the easiest ones to reach.Zwave stick. Plugged into the 2.0 rear slot. I do have it on a right angle usb adaptor so the stick is vertical.PLM cable. Plugged into the middle 3.0 slot.Thank you Bob, you are a scholar and a gentleman. 😉I got a USB extender cord to accommodate the dongle, have it up on the wall behind a cabinet. That also makes connection in cramped plug architectures not an issue.Just looking at aartech, too bad, no BF sales on the Eisy Lite, at least it is in stock. Will hope to duplicate your success in the near future.Orest Edited 7 hours ago7 hr by oskrypuch
7 hours ago7 hr I have noticed my zwave is more stable with the eisy-lite and pg3 integrations are running better - quicker startup especially Yolink and elk which always seemed to take several hours to correctly access all devices.
7 hours ago7 hr Author @bob123What about the portal account? Did the new Eisy give you a new account, or did you get an option to just move the portal account over to the new hardware, together with all the definitions? Seems to me, that is what I did years ago, when I upgraded from the 994.Orest Edited 7 hours ago7 hr by oskrypuch
7 hours ago7 hr I just logged into the portal and transferred the license to the new eisy. Everything worked- no problems with existing Alexa integrations.
7 hours ago7 hr A new eisy usually comes with a free 1 year portal subscription. If you have lots of time left on your Polisy portal subscription and don't need it anymore, you might try asking UDI if they can stack the remaining time with your subscription of your new eisy.
1 hour ago1 hr Author 5 hours ago, Guy Lavoie said:A new eisy usually comes with a free 1 year portal subscription. ....But, if you use the new portal subscription, with the new device, doesn't that leave your UDM and other definitions from your previous device behind?Orest Edited 1 hour ago1 hr by oskrypuch
1 hour ago1 hr 1 minute ago, oskrypuch said:But, if you use the new portal subscription, with the new device, doesn't that leave your UDM and other definitions from your previous device behind?OrestYes, I don't think there is an easy way to migrate customizations and favorites. Good question.
