Could Not Connect to FLIRC After Migrate PG3-eisy
I'm having the same issue as mmoore99 "elSYIR not working after upgrade to OS14.3/IoX 6." That topic has been closed, so I cannot comment there.
After migrating the eISYIR plugin to eisy and updating the latest production versions, the error code shown in the attached screenshot (Cannot connect Flirc device) appears. The plugin and Flirc device work properly in PG3, and fail after migration to eisy. When I reverse the migration, moving eISYIR back into PG3, it works.
During the last 3 weeks, I've re-migrated this plugin multiple times, including after the most recent update to eisy software, but the error always appears after migration to eisy.
I've tried the following steps multiple times without any resolution to the problem::
I disconnected/reconnected Flirc USB. I rebooted eisy. I reinstalled the eISYIR plugin. I restarted the eISYIR plugin.
Regarding the error message "Could not connect Flirc device. Make sure device is plugged in and permissions are set," I don't know what permissions this refers to, but since it worked before I would assume permissions should be correct.
The log is attached.
eISYIR-log-2026-11-05T19-06-57.076Z.zip
You can generate full log package, that includes pg3 logs as well and PM to me and I will take a look. Chances are it just didn't install properly during transfer and you will likely need to open UDI support ticket.
I have a similar issue. When I migrate back to PG3 it works for an IR command or two then stops responding. I don't see IR commands in the log as I send them.
Thanks for your work on this firestone!
Per UDI, this was fixed in the IoX version that's currently in the "Staging" repo. Once it's upgraded, eisy-IR plugin needs to be re-installed, unfortunately. But, also per UDI, you should be able to backup and restore during this process so set up shouldn't be lost.
I do not believe it's related to this issue. Feel free to turn on Debug logging and send some commands. Write down the times that they worked and the times that did not work and I can take a look. PM log package to me after this.
I upgraded my ISY to the version in the Staging repo. I did have to reinstall the plugin and was able to restore a backup to get my configuration restored. So that's good news! It took a couple of re-boots and unplugging and replunging the Flirc.
I am still having some weirdness with intermittent communication. It seems like commands issued in quick succession don't get received. When I say quick succession I mean like 10 seconds apart. If I wait a few minutes between commands it seems like they work a bit better but not reliably.
I have uploaded my log file.
Edit:
To be clear, I have migrated from PG3x to Plugins after the staging repo upgrade and my issue seems to be tracking about the same as the PG3x before the upgrade.
eISYIR-log-2026-11-15T15-26-47.714Z.zip
Edited by AceRoehrborn
adding clarifying info
Firstone helped me solve this (temporarily) by running Terminal commands to correct permissions.
That lasted until today when I ran the latest updates in eisy-ui. That broke the plugin again. Same error.
Firstone had also said, "Per UDI, this was fixed in the IoX version that's currently in the Staging repo. Once it's upgraded, eisy-IR plugin needs to be re-installed, unfortunately."
Assuming the updates I did today would contain the "fix" I backed up eisy.ui and reinstalled the eISYIR plugin. Afterward, the error was still showing. But after I rebooted eisy , the error disappeared. At this point, it seems like the problem may be resolved.
Just posting this in case it helps anyone else having this issue.
