November 6Nov 6 I migrated and everything blank. Even had AI look into it and said I have to move back.Went back and working fine.Nothing lost. Just need to have this work before they dump PG3X in a few months.jeff
November 6Nov 6 Jeff,What do you mean by everything is blank? Can you see the wirelesstag control node? I had problems finding the wireless nodes. See my solution a few meassages down in this catagory. Once I figured out the strange name for the wireless tag manager and turned on the monitor tags to true. The wireless tags showed up. Working fine since.Eric
November 6Nov 6 Hey Jeff,So I don't have wireless tags in my new home, I left them at my old home . I do have them in my lake house so I can migrate those when back on site, or I can install in PG3 here and then migrate and see what happens.But as always, if you have problems I can't debug without a log. If you try again please PM or email me the logs.Jim
November 6Nov 6 Author 3 hours ago, EricBarish said:Jeff,What do you mean by everything is blank? Can you see the wirelesstag control node? I had problems finding the wireless nodes. See my solution a few meassages down in this catagory. Once I figured out the strange name for the wireless tag manager and turned on the monitor tags to true. The wireless tags showed up. Working fine since.EricNot reading most of the nodes. I am thinking a poll might have got reset and hit limits. Let me work on things here and I will send a log to Jimbo
November 6Nov 6 Author I had to get a new token. I figured this one out. I guess the authentication is the issueDelete the current o-auth and restart plugina new authenticate message will appear.do that and restart plugin againthen set monitor tags to true for all your tag managers.then discover- I had to repear the restart and discover a few times.
