November 8Nov 8 In the course of trying to disconnect the wire to the Z-wave antenna on the ZMatter board in my Polisy, the connector on the board broke ☹️ ( was going to do a firmware update).Predictably, when I powered up the Polisy, all of the z-wave nodes show up but none of them are reachable. Since the boards are no longer available, any recommendations on next steps? My Polisy is running IoX 6.1.2_14 and is/was running fine up to now.Thanks!
November 8Nov 8 Author The push on connector broke off the board itself (and took a piece of the board with it) so not sure it can re-soldered?
November 9Nov 9 Author Can't tell if the trace is intact and the board/traces are so small I'm not sure I can do it since the last time I soldered anything was years ago. So I'm guessing the best alternative is to just buy one of the new dongles that UD mentioned are now supported. And assuming I do that I saw your comment in another post that I need to run the following: http://<your_IP_address>:8080/rest/zmatter/zwave/deactivateZMatterZWave.Thanks for your help with this!
November 9Nov 9 That last step shouldn't be necessary. It was only to revert to the original Zooz dongle. The newer IoX versions are supposed to automatically detect the newer dongles.
November 9Nov 9 Author Got it! So I don't need to do anything to have IoX "uninstall" the previous board? The auto detect will basically install the new dongle over it?
November 9Nov 9 I haven't experienced it myself, but the announcement for support of the new dongles said they were automatically detected.
November 9Nov 9 Author OK. I ordered the dongle this morning and will update if I experience any issues after I install it. Thanks again!
November 12Nov 12 Author Solution Update: Removed the Z-matter board (after doing a backup) and then powered down the Polisy. Installed the Aeotec Z-Stick 10 Pro, powered up and then did a restore from the backup. Rebooted. All of my Z-wave devices are functioning and reporting fine so I can confirm that the automatic detection and install of the dongle worked fine!Running IoX 6.1.2_15 & eisy-ui 1.4.10_2
November 12Nov 12 Thanks for the update! Nice to see a report of a straight dongle replacement to a different type.
