9 hours ago9 hr I added logging of programs to IoX logger. No more frustrating only getting to see the last run of a program when debugging a misbehavior. You can see all the runs and whether it ran then/else. It is all handled through the html interface at port 8765 as before. It will log all program activity when enabled for a selectable period of time. You can search the log within the html window, or you can download a csv file and use your preferred program to organize and search it. I also added authentication to open the html control page. To enable the logging, you will need to enter your LOCAL iox username (admin) and password. Not the portal credentials.
6 hours ago6 hr @apostolakisl I got hung up accessing the Web Interface.http://192.168.1.3:8765/ results in the following in Chrome:
6 hours ago6 hr Author 3 minutes ago, Ross said:@apostolakisl I got hung up accessing the Web Interface.http://192.168.1.3:8765/ results in the following in Chrome:Are you running 1.1.0 or 1.1.1. I had that issue as well and thought I figured it out and fixed it with 1.1.1. I'm hoping you are 1.1.0 cause if not I have to look at that some more. The plugin was running and logging, but the html wasn't working. Currently I am not having issues running 1.1.1.EDIT: I see the issue, https:// not http:// Edited 6 hours ago6 hr by apostolakisl
1 hour ago1 hr Author 25 minutes ago, Ross said:@apostolakisl Unfortunately, 1.1.1.did you use https:// your screen shot shows http://
