7 hours ago7 hr Not big issue but it seems that devices that report on/off status are reporting “0 or 1” in UD Mobile and “Internal Server Error” in Eisy-ui. Other devices reporting normally.Remember seeing this a while back.😀
6 hours ago6 hr Can you give a device example and ideally a log with debug. I had to change stuff to get eisy-ui working better so it is likely a minor bug that is easy to fix
6 hours ago6 hr Author 20 minutes ago, Panda88 said:Can you give a device example and ideally a log with debug. I had to change stuff to get eisy-ui working better so it is likely a minor bug that is easy to fix YoLink-log-2026-11-14T17-53-06.802Z.zip
3 hours ago3 hr Author 8 minutes ago, Panda88 said:give 1,.8.80 a spinWorking as it should! (Can’t believe I had to wait an entire hour for you to fix this 😂🤣😂)Thanks!
51 minutes ago51 min Author Must’ve put the curse on you….Im on 1.8.80 and status is correct but I’m back to programs and scenes not firing with motion sensors and door sensors. Like before the status changes in the app, UDMOBILE, and Eisy-ui. YoLink-last-two-hours.zip
