November 17Nov 17 After working on several plugins and Programs the last week I have some suggestions to make the UI more efficient:Is there any way to specify more compact rows in programs, nodes and variables, they take so much more screen real estate than in admin consoleWhen is the new more flexible widgets/main page coming that was shown at the roadmap webinar? I'd like to be able to see and set valiables on the main page not just nodes in tiles. maybe that will allow this?When you go back into the node selector while editing a program, it should remember what node you closed the selector on in a previous edit so you don't have so many lines to go past to find the correct node. also it could open at the node you last selectedWould be nice when in sub-windows like the property selector window and edit variable window, if the window could be moved with the mouse so you can see see what's behind it.When viewing nodes and scrolling in eisy-ui you have to use the side scroll bar, normally the center wheel on my mouse allows scrollingIt would be helpful to be able to replace things like ${var.2.138} and ${sys.node.ZY081_118.CLITEMP} in the notifcation templates with friendlier names they have in programs. Allow sorting the notification templates into alphabetical order. It would be helpful when using the search function in programs that it would also search inside the programs so I can find who uses what variables.It would be helpful to have an option to keep the 3 bar (hamburger icon?) main menu open all the time which avoids having to use the mouse to find the menu every time. or at least a keyboard shortcut or open it when you hover over something on the left side.I'm anxious to hear other's thoughts.
Wednesday at 05:16 PM4 days On your last question about the hamburger icon, I found a "Pin sidebar" option at the very bottom of the menu, if that helps....
