23 hours ago23 hr Hi,I've been pushing off the upgrade to Eisy for as long as possible but I don't want to get to the point where I can't access my devices. Some questions. I am super used the Admin Console. Is the new plat form similar or totally different? I liked the basic retro configuration.I have over 200 devices and tones of programming. Will all of that easily transfer over? Will the old Insteon PLM from my isy994 work with Eisy?I have a campus with one Polisy and multiple ISY994s (some buildings run off Insteon). Is there a to only have 1 Eisy control all of these devices?Thanks,Sam
23 hours ago23 hr The new user interface is eisy-ui. It's still in development, though largely operational now. Some key features such as Find/Replace are still missing. They are tageting mid December to have it complete. It works on both the Polisy and the eisy. You can currently still use both Admin Console and eisy-ui, though you'll find some things not looking quite right in Admin Console with the newer IoX releases.Yes, that should largely be easy to do.Yes, though you'll need a USB to serial adapter, because the eisy has no serial ports.Yes, you could combine several controllers into one, if the device commuications can bridge the physical area.If you have Z-Wave devices, that can be a bit more work to carry over.
23 hours ago23 hr Author Thanks I did not realize I can keep my Polisy and just use eisy-ui interface. Can you expand more on item 4. All of the buildings are on the same network except insteon doesn't use wifi or matter to communicate. Would I need to install insteon repeaters?
23 hours ago23 hr Yes, the Polisy is officially no longer supported, and a few things like Matter won't work on it. It will also fall behind over time because it's version of FreeBSD cannot be upgraded to the latest versions. But eisy-ui does work on it. I have a few Polisys that I use for testing.Just from your user name, I'm guessing that you have several buildings in a camp layout. Depending on how far apart the buildings are, Insteon may or may not work reliably across gaps if the distances are too large. You would need to test this first, with something like appliance or lamp modules to see if you can reach them. I hope you at least have dual band devices.
22 hours ago22 hr 1 hour ago, Camp Romimu02 said:Thanks I did not realize I can keep my Polisy and just use eisy-ui interface. Can you expand more on item 4. Is your electrical system all behind a single meter? If so, chances are better that Insteon will work between them. Also, depends on how far apart the buildings are. If they are next to each other, then Insteon RF will move between them even if on different electric service. I succeeded here with two buildings that were several hundred feet apart by basically running an extension cord from one building to just inside the other building. I got a 500 foot spool of lamp wire which I ran through a conduit, put a male plug on the source building and a female plug on the wire at the other end. I plugged the wire into an outlet next to my plm in building 1 and plugged a dual band Insteon device in at the far end of the "extension cord". I fused the wire at 100ma plus gfci to partially compensate for the complete lack of code compliance. It works great for now like 15 years. The lamp wire takes the Insteon traffic via power line communication to the second building and then the dual band device in building 2 emits it as rf that devices in building 2 pick up and then rebroadcast as both rf and plc. So two buildings 500 feet apart on two different electric services all are on one Insteon network.I also have both buildings on the same LAN, so all of my IP devices running on IoX plugins work great in both buildings.I have a Polisy at this location and installed eisy ui on it. It works fine, but as mentioned, it may not accept future updates. There are instructions on the forum for updating a Polisy to Eisy UI. And as mentioned, the Java ad con still works. Currently I mostly use the Java console but am slowly using eisyui more and more. In my opinion, the eisyui is a mixed bag of superior/inferior to the old console. Some things I can do far faster on the old ad con and some things I can do quicker on the eisy ui.
16 hours ago16 hr Author Thanks for the recommendation. The distance between the buildings using insteon is very far. They are on different meters.
4 hours ago4 hr ...or if you have a "main" location with several, smaller remote buildings, you could use IP based devices for those remote sites, if you have an ethernet network that covers the whole camp. Matter uses IPv6, though you would need to upgrade your Polisy to a eisy to use Matter.
3 hours ago3 hr Author That's what I do now. Polisy does have some matter capabilities but it's a bit flaky.
