Moving from Polisy to Eisy Lite
Do I need the Serial PLM Kit? My PLM (years old) is in a spot that's very difficult for me to get to, so I'd like to access it only once - when the new Eisy arrives. Is there a way from my Polisy's AC to tell?
I'd like to order the kit if needed with the Eisy.
That's what I was wondering - can I tell from my AC which one I have?
I should have mentioned I can easily see my Polisy if I can tell from looking at that unit.
5 minutes ago, Athlon said:
Well is the back of your Polisy easily viewed? If you see a serial cable going to the back (back right corner if looking over it from the front) then it's serial. If instead you see a USB cable going next to the power connector (on other side), then it's USB. It's very likely serial.
Serial - Thank you so much! You saved me from having to take my desk apart to move it.
I also have a Zooz 'S2 Stick 700' plugged into the front of the Polisy, but I think I can just moved that over to the Eisy.
Yes, that worked for someone else with a Zooz 700 series stick. Backup the Polisy and restore on the eisy, and move the stick over. The only annoying thing with the Zooz 700 stick is that there is no upgrade path: going to a different device or even just replacing it requires you to redo your Z-Wave setup from scratch.
Thanks again - you saved me a bunch of work.
I only have a half dozen Z-Wave devices, so not a big deal if and when I have to replace it.
When the new unit arrives, I'll do a backup, shut it down, move the stick to the new one and then fire the Eisy up.
