9 hours ago9 hr I have 2 EISY systems in 2 different residences. About a month ago the EISY system in my 2nd residence went offline to UD Mobile but UD Mobile was still able to receive notifications from that system. I was able to connect to this system through the Java Admin console and ultimately did a reboot which fixed the problem. I wrote this off as a one-off problem and this system has been just fine since then.Fast forward to early this morning and the EISY system in my primary residence went offline to UD Mobile with the same behavior as what happened a month ago on the 2nd residence system, ie. I still get notifications from the system in UD Mobile but it shows as offline in UD Mobile and it also shows as offline when I login to the UD Portal. I can connect to the EISY system using the ESIY-UI web connection and everything appears to be normal. I have not yet rebooted this system to see if a reboot corrects the problem. One additional detail, I have Unifi network gear at both locations and both Unifi system did a software update last night. The Unifi system at my primary home updated at 1:38 am while UD Mobile logged my EISY system going offline at 1:27 am. The closeness of these 2 events may just be a coincidence but the fact that the EISY system went offline 11 minutes before the Unifi system did it's update seems indicate that the 2 events were unrelated. In addition the Unifi system at my 2nd residence updated itself last night with no detrimental effect on the EISY system there.Has anyone else seen this type of problem? Should I check for some other configuration issue before trying the reboot? Both systems are currently running IoX ver 6.1.2_10 and UDX ver 5.1.0. ThanksMike
8 hours ago8 hr If the controller is still functioning check the eisy-ui logs around that time, start with -5 minutes before the disconnect message. There is about a ~2 min debounce for disconnects.
5 hours ago5 hr Author 2 hours ago, Javi said:If the controller is still functioning check the eisy-ui logs around that time, start with -5 minutes before the disconnect message. There is about a ~2 min debounce for disconnects.I ended up rebooting eisy which fixed the problem (as I expected). It is entirely possible that the eisy problem is directly related to the software update that occurred on my network router. While the routers log shows the update happened after the eisy disconnect the router update likely started well before the log entry which would explain the time discrepancy between the stated router update and the eisy disconnect. One interesting thing I see in the eisy-ui log is there is a repeating entry in the log for "isy: Subscription vsid 0 had 2599815 events for the last 239 hours and 49 minutes" where the entry changes every minute. After the router rebooted and eisy reconnected to the network this entry no longer occurs in the log. Perhaps there was something going wrong before the router reboot which caused eisy to not fully recover after the router was back online?Here is the eisy-ui log from around that time -2026-11-27 01:09:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:10:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:10:34 [debug] isy: Subscription vsid 0 had 2598777 events for the last 239 hours and 42 minutes.2026-11-27 01:10:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:10:57 [debug] udxPoll: UDX sanity check2026-11-27 01:11:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:11:34 [debug] isy: Subscription vsid 0 had 2598977 events for the last 239 hours and 43 minutes.2026-11-27 01:11:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:12:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:12:34 [debug] isy: Subscription vsid 0 had 2599106 events for the last 239 hours and 44 minutes.2026-11-27 01:12:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:13:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:13:34 [debug] isy: Subscription vsid 0 had 2599241 events for the last 239 hours and 45 minutes.2026-11-27 01:13:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:14:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:14:34 [debug] isy: Subscription vsid 0 had 2599360 events for the last 239 hours and 46 minutes.2026-11-27 01:14:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:15:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:15:34 [debug] isy: Subscription vsid 0 had 2599486 events for the last 239 hours and 47 minutes.2026-11-27 01:15:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:16:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:16:34 [debug] isy: Subscription vsid 0 had 2599678 events for the last 239 hours and 48 minutes.2026-11-27 01:16:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:17:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:17:34 [debug] isy: Subscription vsid 0 had 2599815 events for the last 239 hours and 49 minutes.2026-11-27 01:17:56 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:18:26 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:18:34 [debug] isy: Subscription vsid 0 had 2599962 events for the last 239 hours and 50 minutes.2026-11-27 01:19:34 [debug] isy: Subscription vsid 0 had 2600025 events for the last 239 hours and 51 minutes.2026-11-27 01:20:18 [error] isy: Error received on reportUrl socket: read EHOSTUNREACH2026-11-27 01:20:18 [info] isy: Subscription vsid 0 was stopped.2026-11-27 01:20:18 [info] isy: Unsubscribing from eisy events2026-11-27 01:20:18 [debug] mqtt: MQTT client eisyui_events_82ce83 Closed2026-11-27 01:20:18 [info] mqtt: MQTT client eisyui_events_82ce83 Ended2026-11-27 01:20:18 [info] mqtt: MQTT client disconnected2026-11-27 01:20:21 [error] proxy: Proxy connection to wss://ProxyWS-1198252322.us-east-1.elb.amazonaws.com closed with code 1006. Reconnecting in 5s...2026-11-27 01:20:26 [error] proxy: Error connecting to dispatcher GET https://my.isy.io/dispatcher?multi=true&ws=true&lb=true: Error: getaddrinfo EAI_FAIL my.isy.io2026-11-27 01:20:26 [error] proxy: Failed to connect to proxy: No proxy available. Retrying in 10s...2026-11-27 01:20:36 [error] proxy: Error connecting to dispatcher GET https://my.isy.io/dispatcher?multi=true&ws=true&lb=true: Error: getaddrinfo EAI_AGAIN my.isy.io2026-11-27 01:20:36 [error] proxy: Failed to connect to proxy: No proxy available. Retrying in 15s...2026-11-27 01:20:51 [info] proxy: Connected to proxy at wss://ProxyWS-1198252322.us-east-1.elb.amazonaws.com2026-11-27 01:20:51 [info] proxy: Connection to proxy is confirmed.2026-11-27 01:21:01 [debug] ioxPoll: IoX sanity check2026-11-27 01:21:21 [error] proxy: Proxy connection to wss://ProxyWS-1198252322.us-east-1.elb.amazonaws.com closed with code 1006. Reconnecting in 20s...2026-11-27 01:21:42 [info] proxy: Connected to proxy at wss://ProxyWS-1198252322.us-east-1.elb.amazonaws.com2026-11-27 01:21:42 [error] proxy: Proxy connection to wss://ProxyWS-1198252322.us-east-1.elb.amazonaws.com closed with code 1005. Reconnecting in 25s...2026-11-27 01:22:07 [info] proxy: Connected to proxy at wss://ProxyWS-1198252322.us-east-1.elb.amazonaws.com2026-11-27 01:22:07 [info] proxy: Connection to proxy is confirmed.2026-11-27 01:22:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:23:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:23:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:24:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:24:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:25:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:25:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:25:57 [debug] udxPoll: UDX sanity check2026-11-27 01:26:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:26:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:27:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:27:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:28:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:28:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:29:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:29:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:30:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:30:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:31:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:31:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:32:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:32:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:33:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:33:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:34:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:34:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:35:07 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:35:37 [debug] proxy: Proxy connection check: Successful.2026-11-27 01:36:01 [debug] ioxPoll: IoX sanity check
