8 hours ago8 hr I'm kind of surprised that no one has brought this up (or I haven't noticed it) but when editing a command where you choose a variable from your list of defined variables, they're listed in index number order. It kind of defeats the advantage of being to give variables meaningful names. You need to either memorize the index number of the variable you're working with, or search for it in the long list, which has it's text center justified, making the snaking beginning of the variable name even harder to find. Could they either be in ASCII order (like in admin console) or have a sort order button allowing us to choose? Having the names left justified would also make it easier to read through. I've never seen a programming tool with a list box showing center justified values.
8 hours ago8 hr Or start typing, the list can be filtered. Similar to all command subsets values that are not a range.
