4 hours ago4 hr In the old AC when you select a scene you could then select a device in scene management and then change how if functions in the scene. See screenshot. How is this now accomplished in eisy-ui?
4 hours ago4 hr Solution 32 minutes ago, TJF1960 said:How is this now accomplished in eisy-ui?From the "node" list, choose a scene. At the right should be a list of all the member in the chosen scene. Controllers in that member list will have a little arrow to the left of the member name. Click on that arrow. This will display all the responders and, for each, give you an option to change the responder's response to the selected controller scene command. Edited 4 hours ago4 hr by oberkc
3 hours ago3 hr Author Thank you! I had tried everything I could think of to change the function of 1 device in the scene, Except to clicking on the scene arrow...Works like a charm.Thank you!-Tim
