Error - Request Failed / on save program
Folks,
I just dug up my older unit and installed the latest firmware 2.7.15
i cleared everyting out and now i am unable to even save the simplest of the simple program ... 'send x10 'I9/On (3)'
when i go to save i get 2 dialog boxes with "Request Failed"
common?
I cant save anything in programing
Is the Error LED on or blinking on the ISY? That would be an issue with the SD card.
Otherwise this usually indicates a firewall blocking writes to the ISY.
Rand
no firwall on the pc i am using - and no error (I did reseat the SD card)
cant really do anything with it if i cant save a program =(
that would be the issue - i could never get this to work right -
so now what?
You may also want to look at the connector on the PLM and make sure the pins are not bent up too high.
