having trouble with "Last Run" in a program
I want something to repeat every other day. So I tried the time since Last Run and it worked for 2-3 cycles. Then it stopped working. I noticed that the last run date & time for this program was now blank. I have reset this and it works for a few cycles then stops when there is no last run data.
Is there a better way to do this?
Mike Dimas
Is there another condition in the program that would prevent it from running on the day it stops? Can you cut & paste the actual program in a message here?
Here is the program.
Time is 5:00:00AM on 2010/09/01
Or Time is Last Run Time for 'Front Sprinkler Every Other Day' + 48 hours
Set 'Outside Sprinkler - Front 1' On
Wait 30 minutes
Set 'Outside Sprinkler - Front 1' Off
Wait 10 seconds
Set 'Outside Sprinkler - Front 2' On
Wait 30 minutes
Set 'Outside Sprinkler - Front 2' Off
Wait 10 seconds
Set 'Outside Sprinkler - Front 3' On
Wait 25 minutes
Set 'Outside Sprinkler - Front 3' Off
Wait 10 seconds
Set 'Outside Sprinkler - Front 4' On
Wait 30 minutes
Set 'Outside Sprinkler - Front 4' Off
that didn't work. looks like the first station came on just for a moment.
it shows Last Run 2010/09/23 05:00:01 Last Finish 2010/09/23 05:00:01
here is the code
       From     5:00:00AM on 2010/09/23
       To       5:00:00AM on 2010/09/23
       Repeat Every  48 hours
          Wait  30 minutes
          Wait  10 seconds
          Wait  30 minutes
          Wait  10 seconds
          Wait  30 minutes
          Wait  10 seconds
          Wait  30 minutes
Mike Dimas
