Bathroom lights motion program
Here is what I came up with for our bathroom lights with adding a motion sensor. I had to come up with an idea on how to avoid it shutting off the lights when someone is in the shower where it won't pick up the motion, so I have included a "bathtime" schedule where the delay is longer.
Master Bath Motion
       Control 'Master Bath / Master Bath Motion' is switched On
   And Control 'Master Bath / Master Bath Motion' is not switched Off
       Run Program 'Master Bath Lights Check Bathtime' (If)
Master Bath Lights Switched On
       Control 'Master Bath / Master Bath Main' is switched On
    Or Control 'Master Bath / Master Bath Main' is switched Fast On
    Or Control 'Master Bath / Master Bath Tub' is switched On
    Or Control 'Master Bath / Master Bath Tub' is switched Fast On
Master Bath Lights Switched Off
       Control 'Master Bath / Master Bath Main' is switched Off
    Or Control 'Master Bath / Master Bath Main' is switched Fast Off
    Or Control 'Master Bath / Master Bath Tub' is switched Off
    Or Control 'Master Bath / Master Bath Tub' is switched Fast Off
       Stop program 'Master Bath Lights Delay 5 Min'
       Stop program 'Master Bath Lights Delay 30 Min'
       Set Scene 'Master Bath / Master Bath' Off
Master Bath Lights Check Bathtime (disabled)
       From     6:00:00AM
       To      Sunrise +  1 hour  (same day)
    Or From    Sunset  -  1 hour
       To      11:00:00PM (same day)
       Run Program 'Master Bath Lights Delay 30 Min' (If)
       Run Program 'Master Bath Lights Delay 5 Min' (If)
Master Bath Lights Delay 5 Min (disabled)
       Program 'Any "Master Bath" Lights On' is True
       Wait  5 minutes
       Run Program 'Master Bath Lights Switched Off' (Then Path)
Master Bath Lights Delay 30 Min (disabled)
       Wait  30 minutes
       Status  'Master Bath / Master Bath Main' is not Off
    Or Status  'Master Bath / Master Bath Tub' is not Off
Round two. I reworked this program, the first version had places where it could go awry. This version also will have the basic function even when the motion sensor does not work or batteries go.
I like your thought about using the time of day to determine whether someone might be using the shower. Very creative.
Thanks! This has worked well so far, no one has yelled out, "I'm in the dark, can you PLEASE turn the lights back on". :-)
  • 4 months later...
I see how you can program the delay, but how many delays can you set? Also, if the delay int he morning is longer than in the afternoon, what is the typical delay you use? I think this could be a tricky function, but I do see the value in making it different.
